cold, closed end, close to kitless
See more from paintspill
paintspill
toronto, ontario, canada.
so is skipped out to the shop. or skated might be more accurate considering the ice storm that hit last night, luckily we still have power. so i went out to the shop to turn the cap on this pen, i made the other part a few nights ago. this is the first successful acrylic double closed end that i have done. this one actually blew up on me a few weeks back but i stuck with it. its based on the baron hardware, i did away with most of the rings and i turned down the coupler a little. i think i'm gonna set up some kind of buffing rig and try to polish it out a little more. but i like it over all. i went with a thicker bottom end so it fits the hand really nicely.
thanks for looking and merry christmas everyone
SDB777
Cabot, Arkansas USA
Did you use a 'pin' chuck to do these closed-ends?
The ribbon blanks don't like to be cold turned(my opinion from past results), that's probably why you had issues...
Good for you to stick with it!!!!
Scott (got sawdust everywhere...woohoo!!) B
paintspill
No I don't have a pin chuck. The first blow up was when I turned too thin and had it between centers and it broke.
These i also did between centers, polished half then held the polished half in a pen drilling chuck. Not the best method but did the job.
jmbaker79
Raleigh, nc
Nice work on the cap, would like to see a view inside the cap. When I make faux cigar pens that's basically what I do. Reshape the metal center and section to fit inside the tube, or did you drop it all together?
