Denim Nouveau Sceptre ballpoint
See more from edstreet
edstreet
No longer confused....
This is 50 layers per inch compressed denim in epoxy. I put it on a nouveau sceptre ball point in black titanium.
This block is 4th block of denim micarta that I have made recently. Have had some good results with the setup I am using.
attachment.php
attachment.php
These are after some sanding on the rod.
attachment.php
attachment.php
attachment.php
This is more raw from basic roughing.
attachment.php
edstreet
Negative on rolling. This is compression. 50 layers of 11 1/2 oz denim compressed to 1 inch. Standard brass tube from the kit.
edstreet
Very cool nice looking pen. What type of finish are you using, it doesn't look like CA.
Mike
Not a CA finish by any stretch of the imagination. It is just pure denim and epoxy sanded and buffed. No need for a CA finish either. Most will tell you they like the feel of a rougher denim micarta over a glass smooth texture. You could do a CA finish I suppose but it's not needed.
These are some other denim micarta projects that I have done in the past
attachment.php
attachment.php
The last image is the kitchen knife and about 15 layers.
carlmorrell
Cary, NC
I have a vacuum press for veneering & curved lamination. Would that work? I could use a reason to get a few old pairs of jeans out of my closet.
