Is this sharp (with japanese waterstones)?
edstreet
No longer confused....
Hello my name is Ed and I have an addiction to Japanese waterstones!
Ok got that out of the way, now down to business.
First the chisel is a new skew in HSS steel that I recently bought in a set.
attachment.php
This is how they come from the factory. Yes it can cut but it's like most things, some assembly required.
Here we have my Lee Valley MKII hone guide with skew registration jig in place.
attachment.php
attachment.php
The secret to sharp is consistency. So do yourself a favor and buy a jig of some form.
attachment.php
Oh yea this is Aoto, Blue Mountain natural Japanese stone. Approx 2,000 to 3,000 grit range, 5-10 microns. Or so they say. This is a very very fine sedimentary stone and the slurry from this feels like a film. Using this stone literally feels like washing a chalk board, it is smooth and silky. Stones like this is what gives Japanese waterstones that sexy appeal and that calm serene flair.
attachment.php
attachment.php
Slurry is made by rubbing another stone on top of the big one. In the above 2 photo's I used 2 types of stones, Omura and Nagura. The white color one (top) is the Nagura, that is around 6,000 to 8,000 grit there about. It helps to remove the finer sediment in the stone. The Omura (bottom) is more of a grinding stone, it is a more coarse grit stone around 150 grit, it brings out the larger grit so you can get a good range of grit from the same stone, try that one with sandpaper! It also flattens the stone. The color here you can clear see why it is a blue stone.
Notice the Su holes or voids, the pockmarks in the stone face, this is gas bubbles that was trapped when the stone was forming however many years ago (read million/billion) They serve several purposes, it traps and holds water and sediment that has broken loose. It can also trap and hold metal shavings from the tool so that must be cleaned off from time to time.
attachment.php
attachment.php
This is a natural Japanese Binsui Stone, approx 300 grit, 60 micron. The slurry from this feels like sandpaper, this particular stone is one of the more advanced stones and not beginner friendly by no means. This is a somewhat coarse grade sandstone.
attachment.php
attachment.php
attachment.php
attachment.php
attachment.php
Here we see what the old vs new slurry looks like. The dark is filled with metal shavings from the chisel, some stones like kitayama they leave it on the stone face, others in the slurry like this Binsui.
attachment.php
attachment.php
These two is a natural Japanese Kaisei Stone, approx 500 grit, 35 micron. This is a very fine grit sandstone. This stone is a VERY stupidly fast cutting stone. It is over very quickly and you can do some serious metal sculpting with the right work flow. This is like Ao-to (blue mountain) but cuts much faster. Both of these are a dream and a pleasure to work with.
attachment.php
attachment.php
attachment.php
This is a small sample of stones that I have so far. In the back is my MKII hone, a knife hone and the spyderco sharpmaker. The bottom row is Binsui, Kaisei, Aoto blue mountain, Uchigumori and kitayama.
attachment.php
Now lets look at the results they do on the chisel.
Above I posted the starting look of the chisel. Here we have after using the stones.
attachment.php
Image is slightly on the small side but enough to barely make out some problems that I encountered along the way. The most notable is Kaisei and Ao-to needed more truing work, need some more Binsui work as well as there are a few scratch marks still that could be removed. However after using Kaisei there is a very sharp edge, after using Ao-to you can shave with the edge.
One final thing I wanted to mention. The #1 problem with sharpening on any stone is consistency. This is where a jig comes in handy. This is also where a sharpie marker is very valuable as well. Just mark the edge where you are sharpening.
attachment.php
Then start sharpening, look after 1-3 cuts
attachment.php
Then adjust as needed and do a few more cuts
attachment.php
Then before long you will be done, then move to the next stone. (trash left to show the bur)
attachment.php
I have purposefully left out the final polishing work that is mostly needed on knife and sword surfaces for visual effects. I have added some aspects in but I wanted this to be mostly about sharpening.
As for the type of stone and the type of steel is a very great important factor to consider when you pick which stones to use. Same holds true for man made synthetic stones, if they do not match the progress will be very slow going.
Also all stones requires some type of soak, some just need to wipe water on it with your hand and others need to soak in water. This helps soften them up. What you are looking for is water retention, soak the stone long enough that water will stay on the surface. Synthetic stones with bonding agents need no soak time and wiping them with water will do. Remember each stone has it's own personality and you have to listen and read the stone to see what it needs.
The biggest question that most will likely ask is 'why sharpen this way when 10 seconds on a grinder will work' The answer lies in the fact that a) this is a HUGE stress relief b) it is soothing c) it allows you to sharpen in ways you have never seen before d) you really get to know your tool and e) it is fun and enjoyable.
Ed
jbswearingen
Bowie, MD
It's pretty, but that's too much daggone work. In the time needed to do all that, I've touched up my blade three times and turned two pens. I'm not knocking you; I understand "different strokes for different folks".
edstreet
[ytmini]E7QaAwlRaqM[/ytmini]sharp testing on cocobolo x264
This is the chisel. I did a small video with my iphone (all the video I have currently) This is a block of Cocobolo.
I also did a small sample one of a dull chisel to give you some idea of the difference.
[ytmini]fykYn1BmAiQ[/ytmini]dull factory chisel x264
rherrell
Pilot Mountain, NC
I agree that bench chisels need to be that sharp but all you need to sharpen turning chisels is an 80 grit bench grinder. I used to sharpen my turning tools with a Tormek but I was spending more time sharpening than turning!
edstreet
The problem of 'how sharp' is a tricky question to be honest. The answer lies somewhere with 'what will you be cutting'. Say you are working with something super delicate, soft and very prone to exploding. Obviously in that case a super sharp chisel is going to net you more favors. The other trade off factor is speed you want something that will do the job fast and not have to spend eternity sharpening chisels. We see post on IAP here all the time where the person has dull chisels and they cause more problems than not. So far I have not seen a post where the problem was the chisels was TO sharp :)
For some things this chisel would be to sharp, for other materials it would be close to right.
The other thing I wanted to point out here is a good amount of the sharpening area that I did in this article is cleanup work from manufacturing, it has very little to do with cutting itself and more like the spine of a knife rather than the cutting edge. Once this initial cleanup polish is done a micro bevel is all that is needed. This is mostly 'pretty work'. I do have another 5-6 stones that I could have used to make it even more sharp, I actually just stopped when I felt it was becoming scary sharp.
I was looking for something hard and difficult to cut. The best thing I could find was a strip of cocobolo. The big ultimate goal was take some of the mystery out of sharpening and show how to get scary sharp and show the stones. Tormek is also a very good setup and I am eventually going to be buying the grizzly T10010 model (same as the Tormek T7 but 10 pounds heavier) and some Tormek jig's plus the big waterstone they have.
The final thing I wanted to mention, there was a few somewhat 'problem' areas on the chisel face as seen in some of the photo's. They were able to be addressed and removed. Plus I now know some very good details about this specific chisel as like hard spots/ soft spots in the metal and with heat treatment itself.
Haynie
Page Arizona
I agree that sharpening is a bit calming. I don't use stones. I use wet dry sand paper on a surfacing stone. Been thinking about getting some stones. What would be the best place to start for a beginner? I am asking because you point out that a stone is "not for beginners".
Sandy H.
Charlotte, NC
I would also be interested in a recommendation for what to buy and when to get it in the learning process.
Currently I have the DMT diamond 'stones' in various grades and wonder how they would compare/contrast to actual stones. My main goal is obviously to learn more about properly sharpening tools and would prefer to use as much of what I have as I can, but if there is a magic piece of the puzzle missing, then it would be nice to know what to add.
Great write-up!
Sandy.
edstreet
What makes a stone 'not beginner friendly' is when you have to do advanced techniques to bring out the abrasives inside the stone. i.e. use both soft and hard grinding stone, use many degree's of dampness on the stone and so forth. You can actually bring up 1,000 grit particles then break them down into finer particles, say 4,000 or 8,000 grit. Think of it as how flour is milled. There was some serious technical article about producing 25,000 grit particles on a stone and it was some serious work and even then it is not a science. In those ranges the stone is very very hard, very expensive and loads of work. My Binsui stone I said was not beginner friendly in the fact that it does take some advanced work to produce swarf. Once things are set up correctly it is fairly easy to work from that point forwards. Also many strokes may not even cut the steel so you are doing work for nothing which defeats the purpose.
My blue mountain stone I would tell anyone who is starting off to get one and use it as that stone is a dream to work with. Also if you are doing any reshaping of the steel then you want something coarser. Other stones that are easy to work is Kaisei and most Nagura (there are a good number of different types).
This is a gent on my Blue mountain stone.
attachment.php
I also have to mention kitayama, this is a man made 8,000 grit final stone, but it is to be used after all the others, even the 12,000 grit stones. It WILL produce a mirror finish in nothing flat and scary sharp is grossly underrated. Here is a pen that I used Kitayama as a backdrop for. I also did not clean it up either and it is all nasty in the photo.
attachment.php
attachment.php
This is a rhodium euro in grape fury that I made.
Here is 3 images from a knife that I made. The blade is one that I bought from a knife supply company. The blade also is flat with no contour and I wanted one on there. Here I used Kaisei and chu-nagura and koma-nagura then bead blasted it.
This is the blade at the start.
attachment.php
This is the blade after the kaisei stone.
attachment.php
This is the final blade structure after nagura. The stone it is resting on is a nagura stone.
attachment.php
Oh and final finish.
attachment.php
The steel you are cutting is the key question, HSS steel is abrasions resistant (read tungsten and vanadium content) so that will cause some problems. This is where the particle hardness comes into play. To rapidly CUT something you need harder; to POLISH something you need equal to or less in hardness and lots of it. You can use softer particles to erode harder materials but it must be in volume
I don't have DMT stones but essentially these are diamond stones on a plate of some form. The pattern they make up on the plate determines a good amount on the effectiveness. Since they use man made diamonds they should effectively cut HSS steel. The only question that does come up is how sharp is the structure and how many strokes will it take. DMT plates will also true waterstones.
The magic piece of the puzzle in all sharpening is this: The angle of the abrasive material MUST be equal to to angle you desire on the blade at all times.
Bottom line is not so much what stone or plate or paper etc you have but how consistent you hold the object to sharpen. Remember this: Consistency is the key. This is where a jig comes in very handy, it honestly does not matter if you put $5 into a jig or $5,000 into a jig as long as you are consistent in the strokes you are good to go.
There is a very good book on sharpening that I have, it covers just about every media and object to sharpen with. Title is "The complete guide to sharpening", Author is Leonard Lee, hard cover and soft cover. He has a dedicated chapters on turning tools and another on scrappers.
Haynie
Page Arizona
I live just left of the middle of no where. If I want something I am going to have to order it. There are a lot of stones on Ebay, good ole woodcraft, and then there is Japanese wood worker. If one was going to get a basic set of three stones which would you start with?
edstreet
Ao-to here, also have other things like holders, etc.
The Epicurean Edge: Japanese and European professional chefs knives
Many good things here.
Sigma Power Select II Ceramic Water Stones - Lee Valley Tools
Sharpening Stones Toishi
This guy sells Welsh slate. I have some of these stone and don't let the ebay thing fool you, this man takes his stones very seriously. He also tests every stones before they are shipped, some very fine work put into these.
NEW SHARPENING HONES, VINTAGE UK HONES items in GREEN SHARPENING STONE SHOP store on eBay!
good site for razor stones.
Japanese Natural Stones Toishi
Have done several orders from this place, shipping can eat you up as EMS bills by weight.
https://www.namikawa-ltd.co.jp/cgi/list_e.cgi
Some other sources of stone, both natural and man made that is not commonly sold in the US.
Japan Tool
Tools from Japan, Japanese woodworking tools direct from Japan.
This one is mostly razors but some others as well.
stone_enter
He also has a youtube channel
https://www.youtube.com/user/japanblades
I am also trying to nail down some Belgium blue waterstones as well :)
Frederick, MD
Interesting read on sharpening.
Personally I use the power hone I use to sharpen my gravers. I go from 180 grit to 1200 grit diamond laps. For my chisels 600 grit seems to be more than adequate. For my gravers I put a mirror polish on them with a ceramic lap charged with 50000 grit diamond spray.
edstreet
Pretty sweet. I am curious how much it would cost to get something close to this set up for a beginner and what places your recommend buying from
Which spray do you use? I know in the past 10 years or so the man made diamond market has exploded with advances.
Oh and welcome to IAP!
Frederick, MD
No. It's in alcohol so it would be volatile and/or evaporate way to quick.
Plus, in the jewelry business there's no real shortcuts to getting a good finish. You either put in the work or you don't. It's what separates the greats from the hacks.
I would guess it might be more useful spayed onto small felt points and buffs. But I've not tried it.
edstreet
I originally steered away from polishing for this but this is very similar to that but more geared towards the razor market.
The three brackets is knife, tool, razor. The difference is hardness, not to be confused with grit size. Stones that are suitable to yield you very fine grit being Awashi, Karasu and Hon-yama. There are synthetic stones that is in this range but they don't come close to the real thing. Kitayama is an 8,000 grit finishing stone, meaning it is the LAST stone you use even if it's 20k grit.
Before I start one thing that I did neglect earlier was some stones benefit from a stone holder. There are various styles available. Many stones will already have a wood base they sit on and the rest you are likely to need a holder not only for movement but support of the stone to prevent breaking, cracking and the like.
attachment.php
Ok. Say hello to Hon-yama Awase Toshi (Hon's mountain finishing stone) This stone is approx 0.5 to 0.75 micron, 10,000 grit size, somewhere there about. But for the most part that does not really matter, it's more about what it can do for us. Long story short this stone is very aggressive. This particular stone is also softer which means more knife and tools rather than razors Working on this stone is pure amazing. Think of this stone as a block of hardened chromium oxide, Linde C compound, Moor white ceramic or similar buffing compound, cept this stone does not wear much at all but does a hellacious job on sharpening and yields a pleasant patina . This is also in the buffing region.
attachment.php
Earlier I posted Uchigumori which is remarkably similar in layout to this one. While Uchigumori is 4,000 grit this one is around 10,000 grit.
attachment.php
1:1 macro shot, the width here is not quite 1/2" wide.
attachment.php
Note the inclusions on the bottom.
attachment.php
Here is both Hon-yama and Uchigumori stones.
attachment.php
Now, After sharpening a 1/2" oval skew that I have (this is from the Benjamin's Best Midi set) I was able to shave with the chisel. Not just any shave but hair popping sharp.
This first one is after Hon-yama. There is a unique patina to the metal. Also worthy of note is the deep scratches going top left to bottom right. Since this is more of a false edge I left it, besides you would really have to look for it to stand out. Second note is the cutting edge itself. That part needs some attention.
attachment.php
attachment.php
After a micro adjustment on the jig to form the cutting edge this is the results. This is also hom-yana still.
attachment.php
Zoom in shot, this is around 0.16" wide.
attachment.php
Keep in mind to the back slope is useful in chip clearing as well as eye candy/visual appearance. On this project the chisel is 1/2" wide and 1/2" slope which had to be changed. I used a 25 degree bevel and an 18 degree skew. This chisel has never been this clean and was one of the first chisels I started out on several years ago.
edstreet
Also interesting to note when you get a chisel this sharp there is very little to no sanding needed afterwards. You could completely eliminate all sandpaper work needed.
sbwertz
Phoenix, AZ
Ed, You find it soothing, but it is said that one of the most effective types of psychological warfare during world war two, was the men in the trenches listening to the enemy sharpening their bayonets!
edstreet
Jigs need not be complicated nor expensive. They serve one purpose, hold at a consistent angle.
Some low-tech solutions are just as viable as very costly solutions so don't overlook those options.
Here we have a 'low budget' jig that I made for a bench grinder. I used scrap 2x4 and 4x4 pine. The 4x4 was turned round and sliced into 3 wedges, then one section sliced off into a D shape. Glued to the flat 2x4 for the top and bottom. The angle is adjusted by a lag screw
attachment.php
attachment.php
attachment.php
These 2 are binsui stones. They are very much beginner friendly.
attachment.php
Some additional stones
attachment.php
Tsushima Natural (top left 2) 6k-8k grit, rest is Omura, bottom front is man made Omura. 150 grit
attachment.php
Tsushima is more of a slurry stone. Omura is mostly used to grind other stones and more used in sword polishing. There are several grades of Omura in the photo, each has different hardness but the same grit size.
Wet grinding.
This is not a modern approach, been around several hundred years and not much different except there is a motor, smaller wheel and package. No heat buildup and not labor intensive makes for a good setup.
attachment.php
before/after sharpening on the wet grinder.
attachment.php
One key part of sharpening is cleaning the chisel, BEFORE it comes in contact with the stone. You want it as clean as possible, no oil at all.
Other things to consider is slate. Some slate makes excellent stones. These are Welsh.
attachment.php
