jmbaker79
SO....I have these two barrels that have been laser engraved, and I have done the color filling on these. I am just looking for a couple of opinions. Because the black lines here are pretty thick, not quite an eighth of an inch wide but close , I worry about their longevity. I filled them with acrylic paint, and am just wondering if I should take some clear fingernail polish to the lines. I think I want to keep the texture of the engraving, so you can tell it is engraved, not a label, etc...So im not sure I want to fill them flush, but most likely would happen with polish, ca, etc etc etc....Is this even a valid concern? Im sure the white initials are good to go, although I would probably try to treat each barrel the same way...Just looking for input as I don't want the paint to rub off during use as Im sure some skin contact will be made while writing....Thanks in advance!
