Has anyone tried the MTBC Bushings for Jr. Gent II from Lazerlinez?
If so what is your opinion?
I'm not sure exactly what you are referring to here.Interesting to note they, lazerlinez, list them for mandrel and TBC. That will introduce some serious slop factor in if you use them on both. Also looks as their bushings has lack of real estate area in the TBC format.
the bottom middle shows the end of the bushing.
With that hole cut out for the mandrel that is some serious lack of real estate when doing TBC mode and lack of grip
"Lack real estate"?? and what purpose would that real estate serve? Other than making the bushing slightly heavier, I can't think of anything.
I'm also not quite able to understand what you mean by "serious slop factor" and why you think using the bushings on both a mandrel and for TBC would have some adverse effect.
were not used on a mandrel it would not have any slop?? Or even if it is not used on a mandrel, it will have slop? Used solely as TBC
I understand now. I tend to think it isn't going to be a real problem for most users...time will tell.were not used on a mandrel it would not have any slop?? Or even if it is not used on a mandrel, it will have slop? Used solely as TBC
Not from the method that I mentioned. The only way I could see that being introduced is a some build up on the dead center or in the bushing gets in the way of metal on metal contact area. The smaller contact area would increase the chances of that happening. However we should all be keeping things as clean as we can so. Then again if you had 100% full coverage on the bushing that to would still be a viable problem that needs to be addressed promptly.
It is essentially like opening a jar with a cloth. The more contact area between the cloth and the jar lid yields more friction and strength you can apply. The question comes down to how much surface area is enough? That is something that I do not know the answer to. Perhaps someone out there does know and posts.
having closed bushings, i.e. Johnny CNC's for example you have very good surface area and there is no problem as it is near 100% coverage. The only down side to this is build up inside the bushing opening, this is not there in the center cut out as in the lazerlinez bushings. So it's a trade off, Strength or Build up? The key solution is in cleaning the bushings
