I am in the market for a new lathe...
What lathe has the least issues
  • Total voters
    21
  • Poll closed .
Chrisjan
Pretoria, South Africa
Hi there,
I just about had it with unbalanced drive shafts, ill aligned tail stocks which are not center height and a damn VVT transmission loosing torque. Therefore I am in the market for a new lathe. South Africa doesnt offer much in terms of different manufacturers and models. What should I choose and why:
  1. JET 1236
  2. NOVA 1624
  3. Other
Jim Smith
Lakeland, FL
While your two choices are fine machines, I think the Oneway is even better. If you're going to all the trouble of having it shipped in, then I would go with the Oneway 1224 or 1640.
Jim Smith
Mack C.
Passed Away Sep 29, 2018
Brooklin, ON Canada
Jim Smith
My sentiments, exactly!
attachment.php
This is my Oneway 1224! I just love turning pens on it. It currently lists at $2500.
David M
Norton, Va. 24273
I can not commet on the jet , I have the nova and it does a very good job . Solid machine , the belt last me about a year and a half . I would get a nother nova again - vs would be nice but its easy and fast to change speeds. Both should be solid machines.
David
yorkie
Charlotte, North Carolina
I am very pleased with my Delta Midi Lathe. it goes in revers too. I've turned hundreds of pens on it and have been very pleased. I had a Jet before it but the Delta is better.
Rapid City,SD
If you are doing pens and small boxes and bowls I love my wilton mini. Now I am turning larger items I use a King machinery lathe.
Levi Woodard
Woodardwoodworks.com
Sent from my Galaxy player using Forum Runner
The Penguin
Houston, TX
I have a Jet 1236...and the the thing I dislike about it most - no hole through the headstock for a knockout bar!
you have to remove the handwheel first, then you can use a knockout bar to remove a drive center.
Whaler
Sequim, WA, USA.
I can't speak for any of those listed but I have the Nova DVR-XP and it is a fantastic lathe.
