Carl Fisher
So I keep a small 3x5 notepad book on my work bench at all times. The kind you would put next to the refrigerator to take notes or write your grocery list on. Although a pad of sticky notes or pack of index cards would work just as well.
I use them for anything from mixing epoxy, mixing paint, I put them under glued blanks to keep them from sticking to the bench, between the clamps and blank when gluing up segments, etc...
The best part, when you're done, just peel the sheet off and throw it away or if it's stuck to the blank after a glue up, just turn it away. When I use them for mixing, typically I'm done with whatever is on the sheet before it has time to saturate down more than the top layer.
