robutacion
Hi peoples,
Here are some of the Platypus Gum Burl termite carved wood, made into BOXES and Bottle stoppers, using PR coloured resin. Also some pen blanks made from the same wood and with the same process, Resifill...!
I brought in also, 30 of my best VINE Shiraz Red PEN blanks and finally some of those Colonial Red Gum under water cure wood that I had found among my knife blanks (3 knife handle blanks) that I totally forgot I cut.
These are the very same quality as those I selected to sell here, a few months ago, they were all exhibition grade, the same apply with these ones.
The only difference is that, and unless I find some that I don't know I have, these have a very good chance to be the very last ones I will ever sell in this grade as I still have some second grade on sale on eBay, these were cut to give no waste from the size I cut my knife handle blanks at (150x50x35mm) so, there are 2 groups, one at 17mm square and the other at 14.7mm so, you will have to be accurate with your drilling...!
Please remember, these blanks are in Australia...!
Freight cost to USA and Canada (please, request quote for any other countries).
All prices are quoted on the Regular Air-mail option, by Australia Post.
Note: An USA Customs sub-charge of $9.00 will apply, with any order to the USA over the 500gr total weight limit
*- 250gr. (USA & CA) -- AU$10.50+$1.50(box)=AU$12.00
*- 500gr. (USA & CA) -- AU$17.25+$1.50(box)=AU$18.75
*- 750gr. (USA & CA) -- AU$24.00+$2.00(box)=AU$26.00
*- 1kg. (USA & CA) -- AU$30.75+$2.00(box)=AU$32.75
*- Other weights, please contact me for quote...!
When you add on the various blanks you are interested in, please remember that the postal box+bubble-wrap+paper work+wrapping tape is approx, 85gr for the small box and 100gr for the next size up.
Weight adjustments are possible by removing the square corners of the blanks. This is a normal procedure to void extra freight charges, unless you advise, to not remove them...!
Pen blanks size average is 21mm square x 130mm long, with exception of those clearly marked differently...!
Please, post here the number of then blanks you are interested in so that other can see what is still available, thank you...!
You will be then contacted with the payments details...!
PAYPAL, only.
*- Platypus Gum Burl #26-B termite carved wood filled with PR coloured resin, BOX square blanks
![101_1893.jpg 101_1893.jpg](https://www.penturners.org/data/attachments/63/63252-26cf1e6b4e3319eee2c56107adcbc6ed.jpg)
*- Platypus Gum Burl #26-B termite carved wood filled with PR coloured resin, Bottle Stopper blanks
![101_1845.jpg 101_1845.jpg](https://www.penturners.org/data/attachments/63/63034-86a4cb962acbed3fd1ce6543403f11b6.jpg)
*- Platypus Gum Burl #26-B termite carved wood filled with PR coloured resin, PEN blanks
![101_1848.jpg 101_1848.jpg](https://www.penturners.org/data/attachments/63/63093-78465d03446a0418ba6bdbf939e2294f.jpg)
*- VINE Shiraz Red PEN blanks, exhibition grade 1 to 10
![101_1862.jpg 101_1862.jpg](https://www.penturners.org/data/attachments/63/63094-4eff074ecb3cd3fec77dcd0122f0d3c1.jpg)
*- VINE Shiraz Red PEN blanks, exhibition grade 11 to 20
![101_1863.jpg 101_1863.jpg](https://www.penturners.org/data/attachments/63/63037-40a295b51cd27a72c0d779d85b1e41fd.jpg)
*- VINE Shiraz Red PEN blanks, exhibition grade 21 to 30
![101_1864.jpg 101_1864.jpg](https://www.penturners.org/data/attachments/63/63095-b780b318d0b4d872a87657e4337d12f3.jpg)
*- Colonial Red Gum #9-S cured under water PEN blanks @17mm square in 6" and 5"
![101_1851.jpg 101_1851.jpg](https://www.penturners.org/data/attachments/63/63035-27efa63aff7ef4fea0910f6d5a098743.jpg)
*- Colonial Red Gum #9-S cured under water PEN blanks @14.7mm square in 6" and 5"
![101_1855.JPG 101_1855.JPG](https://www.penturners.org/data/attachments/63/63036-6d9f2fda4c8af65dc93bfb752eab078d.jpg)
Cheers
George
PAYPAL, only.
Cheers
George
