A Walnut Bolt
See more from skiprat
skiprat
Passed Away Mar 22, 2022
In a Skip in Wales
I had some free time today so I made this walnut bolt pen. It may look ok-ish, but there are several faults. But now I know better for the next one.:wink:
It has a snap cap with the nib recessed slightly into the body ( to hide it)
Unfortunately I cut the body without checking it's length and I had to leave out the spring. :redface: The external cap threads are about 12.5mm x 2mm. They did chip a little in places.
Mad at myself for not checking the measurement !! Oh well, fun anyway:biggrin: Hope you like anyway:wink:
IPD_Mr
Zionsville, In
Very nice Steven. I still use mine every day. It holds up well from my daily abuse too.
Oh well, fun anyway:biggrin: That is the whole point to this isn't it?
skiprat
In a Skip in Wales
No Bob, I used a lathe tool and even rotated the lathe by hand to get very fine cuts. Took forever!!!:rolleyes:
Here's a couple more pics. I hex'ed the blank with a router then turned to size. Then cut the threads, then cut off the threaded end and drilled the holes.
The only neat trick here was to get the exact correct size hole for the snapper was to sneak up on the hole with a boring head.
One of these is better and cheaper than a set of drill bits.:wink:
hewunch
Albany, GA
Now is that a triple start or single start? :tongue:
Seriously, it is great having you back and sharing your creativity with us. NPGJ!:cool:
MarkD
Sayre, PA
Very nice! I love your bolt pens!
Now you need to make a walnut nut to be used as a pen base! :biggrin:
PenPal
Canberra, A.C.T., Australia.
Skippy,
Thankyou in the confines of population we have where do we buy tiny boring heads, I have almost given up on ever getting accurate drill sizes as well.
Your Pen comes up well in Walnut finished neatly and yes it does chip as does most timber, you handled that well.
Wilma starts Chemo and Radiology shortly so I am trying to conquer my Engineering probs in between Docs visits and blind panic.
Great attention to detail, certainly for me much easier than Stainless, mind is buzzing with ideas in Burl Pen Rests with a theme.
Inspiration you engender is important for me and helps me to ponder anew.
Thanks mate.
Kind regards Peter.
jd99
Ontario, CA United States
That's cool but I have a question.
Thats obviously a metal lathe, you used.
How do you keep the wood from turning the oiled ways and the oil in the cross slide/apron into mush, and not getting in the gibs and such? the last time I tried to turn anything wood on my metal lathe or mill for that matter it took so long to get everything cleaned when I was done, it wasn't worth the project.
now I keep the metal shop on one side, and the wood shop on the other and try not to let the dust into my precision machinery, (it can really play havoc with my DRO on the lathe and mill) Don't ask me how i know that. :frown:
Danny
Andrew_K99
Waterdown, ON, Canada
Danny
Amazingly skiprat uses a wood lathe! Check this one out http://www.penturners.org/forum/showthread.php?t=81896
AK
jd99
Andrew_K99
Amazingly Skitrat uses a wood lathe! Check this one out http://www.penturners.org/forum/showthread.php?t=81896
AK
That picture is of a metal lathe, it has a lead screw and V ways, wood lathes don't come like that, the tool holder looks like a standard indexing type also.
22 years in the Tool & Die/Mold Making Field before i retired from it. seen many a machine tool in my time.:rolleyes:
Hmmm, you're right. I'm just going by what I have read. There are videos somewhere too if I am not mistaken.
AK
Andrew_K99
AK
AK
Here is the youtube link to the stainless steel bolt pen made on a wood lathe. http://www.youtu.be/watch?v=WWWUhq1R0kI&feature=related
AK
skiprat
In a Skip in Wales
Many thanks for the kind comments and all the 'Likes':biggrin:
Yes, this pen was made on a metal lathe. I have a wood lathe and a home made rose engine lathe too.
I clean the lathe periodically. I don't abuse it, but it's a workhorse tool, not a precious ornament!! :biggrin::wink:
OKLAHOMAN
Costa Rica
Impostor! Impostor! Impostor! Who are you? Our Skippy has... er uses Stainless nuts & bolts not that stuff that comes from trees...
PenMan1
Eatonton, Georgia
Roy, It appears that "Skippy" is actually a "furry tailed" rat that constantly irritates the pecan and walnut farmers, here:biggrin:
Still a Damned fine looking pen, though...no matter WHERE he gets his nuts.
witz1976
Bucksport, Maine, USA
WOW, seriously! :biggrin:No wonder why you have been quiet for so long. You were practicing new ways to completely blow our minds!:rolleyes::eek:
Once again thanks for making be drool in awe. That is a great piece of work.
