Shave
See more from fernhills
fernhills
Hellertown, PA, USA.
This is something i have been experimenting with for the last couple of years. I like the idea of a wood mug with a shaving set but i could not bring myself to throw a glob of wet soapy mess into the wood bowl and let it soak there for months on end. So i made a bowl to fit those plastic refill inserts which there are different brands on the market today. Plus you should use dense woods and there are only a few to choose from, using the refills frees up your choices of woods and styles of making the bowls. I have been using a Butternut bowl with these inserts and it is holding up great.
The pic is a set made from Canary Wood. Finish with C/A and BLO. inside of bowl i used Tung Oil. Brush is Badger
islandturner
Victoria, BC
These look really good, Carl -- the matching bowl for the soap really completes the set.
I've been thinking about making a couple of sets like this for Xmas presents, and worry about their constant exposure to water on the bathroom cabinet. I wondered about turning the pieces until they're within approx a sixteenth of an inch of the final size and then putting them in wood hardener for a few days -- Minwax or Cactus Juice. Then completing the turning and finishing? That might help the wood survive years of exposure to water and steam.
glycerine
Fayetteville, NC
Very nice. The reason I got into pen turning is because I wanted to make custom handles for some of my old DE razors, maybe a brush and a bowl as well. That was over 2 years ago. When I started researching woodturning, I discovered pen turning and have been stuck ever since. I FINALLY turned a handle for a vintage Merkur slant the other night. One day I'll get to the brush handle and bowl...
fernhills
Thanks for your comments.. I am working on a set now that you would not think is good for a shaving set. Carl
This is what a came up with so far, Spalted Maple or Yellow Birch or Beech, i don`t which it is, but that is what most of my trees are in the land i have in the mountains by my cabin. C/A BLO finish. I will use the bowl at home for awhile to see how it holds up. Carl
KenV
Juneau, Alaska.
Also looks like a good opportunity for pieces of stabalized woods -- the plastics injected should make the water contact less a problem, and allow clean up when fuzzy things start growing.
I like the look -
Thought about glass inserts like the larger candle holders (2 3/4 inside diameter)??
fernhills
I like the look -
I do not like the idea of glass and bathrooms, but must confess, i thought about it to.
I did see something on Etsy and was wondering how he did it. The one like the photo below is the ticket. Carl
