Butterflygirl
This is one of the first polymer clay pens that I have done. Found some canes at Hobby Lobby. This one turned out pretty good for one of my first I think.
Hi - that is totally cool. I've searched for info on making them but not having much luck. Found some sites for the clay but.... stupid question ..what is a cane??
How long did it take to put all the piece on the pen?
Can you turn it, after it's baked? Or do you have to get it shaped before you bake it?
That's a cool looking pen!
Curious on learning more. Did you turn it on the lathe also? Or just make it to the correct dimensions before baking it? Did you go through all 9 grits of the MM? Also did you CA it inbetween sanding or just the top layer?It.Was very fun and pretty easy also did a couple coats of thin CA and med. then finished carefully with micro mesh.
