My Thinnest Yet!
See more from Grizz
Grizz
Banned
Walnut Bowl I worked on today. 5.5" x 2.25" Thickness is less than 1/8"
2 Coats of Clear blond shellac and some wax.
I didn't blow it out ... whew. :)
hewunch
Albany, GA
You are right, that is the thinnest walnut bowl I have ever seen. So thin, I can't see it :biggrin:
OOPS
Spokane, WA
Wow, Grizz, that is an exceptional piece of wood you have there. I really like Walnut myself. Excellent work, thanks for posting it. It looks like you got quite a shine out of that finish too.
ed4copies
Local Chapter Manager
Racine, WI, USA.
WOW, nice wood!!!
The grain in the third one seems to run from one side to the other--great choice of camera angle!!!
Well done, all the way around.
robutacion
Australia - SA Adelaide Hills
Yeah, good execution, simple shape but effective.
The wood is certainly beautiful and the grain/colours did come up very well the way it was finished.
One of the worth enemies of thin wall bowls/vessels, etc, is the outside diameter of the piece, the wider the circle the more vibration/wobble will affect the outer edges of the piece to the point that if rotating too fast, it will simple disintegrate/explode...!:eek:
The 5.5" diameter is a very safe size for these thin wall items but I would suggest caution at the lathe speed on anything under 5mm, over the 7 to 8" diameter. Off-course, the type of wood used will determine its success or failure, some woods will allow a 3mm wall thickness up to the sizes I suggested if lathe speeds aren't extreme...!
Basically, any of these items turned carefully on any mini/midi wood lathe, aren't too bad as the lathe limitations will limit the sizes that can become more of a problem or risk so, all pen-turners with small lathes, making bowls and other stuff out of your small lathe is a good way to break the monotony (if doing too many in a short period of time) and experimenting other turning techniques with some investment in a few extra tools and larger size wood, which is easier to find then most people realise.
Green wood turning is a great way of turning, and something that everyone will find at the local dump, local tree arborist, council workers, and neighbours. Trees have to be trimmed and cut down all the time, every where, keep your eyes and ears alert, and make sure that, when you hear the sound of a chain saw going, go to that location without delay, you will be glad that you did, (51% of the time)!
OK, I stop now...!:eek::redface::wink::biggrin:
PS: Just in case someone wants to have a go at some logs, here is a good PDF file with great information on how to cut logs for making bows, depending on the way you want the grain to show...!
Cheers
George
  • Bowl_Blanks_from_Log_Handout.pdf
PaulDoug
Benton City, WA.
Grizz as I said on "that other" forum that is really nice. I am just finishing a BW bowl up but it is not as nice as yours. Great work.
holmqer
Local Chapter Leader
CT, USA.
Excellent form and execution. No hint of tool marks, bruising or tearout!
I've been doing a lot of thin walled stuff lately to support my piercing addiction.
That's one jim dandy looking bowl.... I was working on one earlier this week that would have, could have, should have, been similar... one teensy weensy, tiny little bitty catch turned it into an exploding mass of wood shrapnel, some of which I think went into the rafters and is lodged in some of the stuff stored up there.... You did really good.... love the looks of a well turned walnut bowl. :good::good::good::good:
ctubbs
Murray, Kentucky
Jon, you have my undying admiration! That is one magnificent bowl. Someday I hope to just turn a bowl, of any kind and any thickness. That is gorgeous. Thanks for showing.
Charles
