Hickory One Piece Slimine 2nd try!!!!!
See more from knight_muzzleloader
Drakesville, Iowa
Hi everyone, second attempt. My picture seems kind of yellow. Hickory slimline, one piece. The "blue" lines, (seem kind of black) is shavings of the last acrylic I did. I crushed them up and made CA slurry. Jim
wb7whi
Spokane WA
Hi Jim. Are you using a sleeve in the lower barrel? Without it is not turning to produce the refill a bit tight?
I have been using the replacement tubes from a purfume applicator that are just a smidge larger ID hat the 7mm OD. You only need an inch or so at the nib end.
Fun stuff eh?
Drakesville, Iowa
HI Wayne, I'm using the tube that came with kit. It is a little tight, but I figured that was newness. I'm having a blast with the "new" slimline. I have never liked the skinny look to the center band. I like the one long straight line.
Fun stuff eh?
