underdog
I'm sure this question has been asked a million times (as well as answered).
How do you successfully apply CA glue finish?
I've finished 8 of my 24+ pens, and I am only happy with the finish on 5 of those.
And it took an inordinant amount of time to apply the finish. I think I've exhausted the requisite number of mistakes one can make. I'm ready to try something that will work, and not take an hour (or two) per pen....:redface:
Here's the history of mistakes. (If you don't care, just skip this and give me your answer).
A couple years ago I tried Russ Fairfields BLO/CA method (on one pen), but failed to implement it because I didn't have any fine sandpaper. Finest thing I had was some ratty 325 (or possibly some 400) grit. So naturally I sanded off everything before I even got started. Finally gave up and applied several coats of laquer. I wore the plating and finish off that pen before the transmission finally gave up. It's sitting in my "repair box" now... (I wish they made the "presidential" in a better finish than 24K. I like that clip style...
This time around, I have 24 pens to make and figured I'd set up an assembly line. I have no trouble with any of the steps, but when it comes to putting the CA finish on... GAH!:angry:
I watched a couple of Youtube vids and figured out to use paper towel as an applicator (I've seen that plastic package padding used also) with the lathe speed turned down. One guys says not to use paper towel that acts as a catalyst (when it instantly cures and starts smoking upon application). The Bounty brand certainly does smoke though (should I use the blue shop towels instead?).
I've seen one vid where the guy uses three applications of thick CA sanding with 800 grit between coats (no accelerator), then a final sanding (w/800) and buffing.
Then I saw another vid where a guy puts 20 coats of thin CA with no sanding in between, but uses accelerator between coats. Then he starts with the micromesh and goes up to 12,000.
Then I saw another vid where a guy puts 10 coats of thin CA on with lots of accelorator between coats, and then runs through the micromesh.
All three of these methods only took a few minutes.....
I've only had partial success with the thin CA, and I had to apply at least 4 coats in order to have any coverage that I didn't sand through- starting with 600. I used the Bounty paper towel to apply it (glued it to my fingers quite a few times), and it kicks off the glue pretty quick. Sand at 600 or 1000 grit between coats to level it off, then wetsanded/buffed with micromesh after letting it cure at least 15 minutes.
I've had a lot of trouble getting a level surface, a lot of trouble sanding through, and in one instance, could NOT get the glue to stick to a spot of the blank (perhaps I had some acetone on that spot?).
And last but not least, it took me four hours to finish 5 pens yesterday. This is just not acceptable.:frown:
You got some advice, tips, help for me? Fire away. And thanks!
*Edit* Oh.. I did set up a couple fan to carry the fumes away, so that helped immensely. I'm not wheezing this morning... I did see the CA that doesn't emit those noxious gasses, and was tempted to buy some of the Gold stuff...
