Square & Multistart threads on wood lathe
BRobbins629
Passed Away Dec 28, 2021
Richmond, VA, USA.
Meet us at the MAPG and see the unveiling of the incredible threading machine. You can cut square or multistart threads on virtually any wood lathe with this low cost jig. No taps or dies needed. Be there and cut square (threads that is).
Multistart thread with home-made thread mill holder
attachment.php
Jig set to cut multistart threads
attachment.php
Close-up of set up for square threads
attachment.php
Jig set up for square threads
attachment.php
2-start thread in alumilite
attachment.php
Square thread in padauk
attachment.php
thrustmonkey
Illinois
Wish I could make it there. Very interesting. Really nice clean threads. What about the cost?
Really nice threads.
BRobbins629
Richmond, VA, USA.
I was fortunate to have most of the pieces lying around. If I had nothing, I think it could be done for less than $100 and probably much less. High cost items are adapter to hold chuck ~$20, acme thread and anti-backlash nut ~$20. Single point thread mills can be $30-40, but for square threads the little dremel tool is only about $5.00.
low_48
Peoria, IL, USA.
Is it just me, or just the photo? But that double start in Alumilite looks like it has two different depths. I'm also wondering about the fit of the nut on a square thread. Isn't the advantage of a tapered cut that you can adjust the depth to bring up a good fit. Isn't the square going to either rattle or be too tight? Seems like the square thread is going to be very difficult to get the fit. Nice jig, just thinking out loud.
BRobbins629
Richmond, VA, USA.
Good eye! Hadn't noticed that on the double start. Either the set-up or a little runout.
Square threads have always fascinated me from the first time I saw the on a pen made by Dan Symonds. Dan now making them for Franklin-Christoph.
Model 19 Fountain Pen - Franklin-Christoph Fine Writing
The thing that makes them work (at least for me) is that the cutter is a few thousands thicker than .050 and that the pitch is 10 TPI. I've only made a few pieces with this, but definitely not too tight and doesn't seem to rattle. One advantage is less prone to chip.
low_48
Peoria, IL, USA.
Thanks Bruce, nice job!
walshjp17
Weddington, NC
Nice jig, Bruce. Perhaps you might want to collaborate with the WC guys to come up with a hardware kit similar to the one they put together last year for the Celtic Knot jig.
