glycerine
Those of you making "kitless" rollerball and ballpoint pens, do you hollow out your nose cones or just drill the small hole and leave it at that? If you're hollowing out, what are you using to do it? Thanks.
Jeremy,
What I do is measure up the refill that you want to use. I get mine at staples. Like Mike said, you will want to step drill the tip. I end up using a D bit (I use a M7x1 to reverse turn) and a #36 or #37 for the tip, depending on how I returned them to the index. See attached for a better visual.
