Are these the vacuum pumps I need?
Rifleman1776
Mountain Home, Arkansas, USA.
The oil less pump will be very noisy. The other looks old and well used. I suggest you go to the Gast web site and look up the model for the used one. It will explain how you can purchase parts and rebuild and old vac pump. You will also need gauges. Some folks also use filters. The pump is just the beginning.
