Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Casting & Stabilization
Casting & Stabilization Making your own blanks & stabilizing wood blanks.
Reply
Old 07-16-2011, 11:55 PM   #1 (permalink)
woodgraver's Avatar
Photos: 14
Default Casting a Laser Cut Wood Blank
The odd things you come up with when you mix together different parts of the hobby. This was my first attempt to cast a pen blank that I had cut with a laser. I just used silmar 41 and coastal scents orange glitter. I did the casting upright in a pill bottle. I should have used my sierra mould because I had some air entrapment in the bottom of some of the flames. I'm going to try and fill those spots with some epoxy mixed with the same glitter...if it doesn't match up, I'm sure the next try will come out better. I've got another blank where I cut the flames from a piece of paduak and then used black mica powder and some silver glitter...I used a lot more coloring trying to make it opaque so it didn't set up as quickly as this one.
woodgraver is offline   Reply With Quote Top
Old 07-17-2011, 12:25 AM   #2 (permalink)
LarryDNJR's Avatar
Photos: 10
Default
Looks good!
__________________
LarryDNJR is offline   Reply With Quote Top
Old 07-17-2011, 12:47 AM   #3 (permalink)
ctubbs's Avatar
Photos: 2
Default
James, that is a good looking first try blank. Keep up the great work.
Charles
__________________
Experts hit what they aim at......I aim at what I hit
Respect - Never given, must be earned
Smile, it makes people wonder what you have been up to or what you are on. Keep then guessing and you keep smiling.
ctubbs is offline   Reply With Quote Top
Old 07-17-2011, 08:08 PM   #4 (permalink)
Photos: 0
Default
Very cool look. Did you use any pressure for the casting?
Don.
Canadian_Kid is offline   Reply With Quote Top
Old 07-17-2011, 09:51 PM   #5 (permalink)
Photos: 13
Default
Great first casting! Nice flames!
__________________
Mark
MarkD is online now   Reply With Quote Top
Old 07-17-2011, 10:04 PM   #6 (permalink)
Craftdiggity's Avatar
Photos: 0
Default
Nifty idea, James.
__________________
Chris Merlino
If at first you don't succeed...
Deny you ever tried.
www.woodntreasures.com
Craftdiggity is offline   Reply With Quote Top
Old 07-17-2011, 11:59 PM   #7 (permalink)
woodgraver's Avatar
Photos: 14
Default
Quote:
Don.
Don, no pressure I just set a pill bottle with 1.5oz of silmar 41 in a hot bath. Once it was the viscosity of water, I added the glitter and 7 drops of MEKP. I then plunged the pen blank down into the pill bottle...the blank had rubber stoppers in each end. This is where I think air bubbles were trapped as I put the blank in flame tips down. I'm not sure if pressure would have helped. I think maybe I would have had better results with alumilite in a pressure pot. The second cast didn't fare nearly as well as this one...I should have put it in a toaster oven...the deep inside didn't set up and when I turned it...well, you get the picture ;)
I'll keep trying...I have an alumillite starter kit...this would be the perfect time to give that a try.
Jim
Old 07-18-2011, 12:20 AM   #8 (permalink)
navycop's Avatar
Photos: 0
Default
Pretty cool. I would like to see the flames red and background black.
__________________
Mike
U.S.Navy (ret)
Shopsmith 510
navycop is offline   Reply With Quote Top
Old 07-20-2011, 12:29 AM   #9 (permalink)
woodgraver's Avatar
Photos: 14
Default
Quote:
Mike, I tried that but the blank didn't setup. I'm going to give it another try this weekend before I head out to a conference in Norfolk next week! Jim
Reply
Bookmarks
Tags
casting , laser inlay
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Content Copyright © 2003-2012 by Penturners.org, LLC; All Rights Reserved
