Casting banksia pods
tpuskar
Howell, NJ
I'd like to make some pens using banksia pods filled with colored polyester resin. Several questions:
1. What dyes should I use?
2. Should I cast under pressure or vacuum or just room temp?
Thanks,
Tom Puskar
Howell, NJ
alankulwicki7
Vadnais Heights, MN
Casting is done under pressure and stabilizing is done under vacuum. Sometimes I will heat the resin slightly but usually I just cast at room temp.
I use mica powders from coastal scents and pearlex powders from Michael's...
KenV
Juneau, Alaska.
Most who are using resin to fill use alumalite rather than PR.
Epoxy is also effective --
There is a history of challenges with the use of PR to cast into cavities.
MarkD
Sayre, PA
As Ken said, Allumilite is better than PR for this application. Allumilite does not shrink. I use Alumilite with pressure to collapse the air bubbles, when casting Banksia Pods.
