Neje Software issue - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Shops, Jigs, Fixtures & Tools
  Forgot Password
Shops, Jigs, Fixtures & Tools Show off and discuss your workshop and everything in it.
Welcome to penturners.org!
Reply
Old 01-09-2019, 11:11 PM   #1 (permalink)
Photos: 5
Default Neje Software issue
I just got the 1500mW Qiilu and am having an issue with the software. I've seen that images should be 550px x 550px, but when I drop them in they get cut off with no clear rhyme or reason. When I put them into the v2.0 software it works fine. I have now tested with 3 different images I made 550x550 and posted screenshots of the results here: https://imgur.com/a/QtpUtd6
Anyone have any pointers for how to get an image to display properly in the 4.0 software?
Thanks!
auldenglish is offline   Reply With Quote Top
Old 01-10-2019, 04:50 AM   #2 (permalink)
Photos: 0
Default
With my NEJE I maxed at about 400px, finally figured out that the measurement scales on the side of the window were fairly accurate. The bed measured larger, but the travel isn't there.
__________________
Jeff Miller
www.MillerTurnings.com
MillerTurnings is offline   Reply With Quote Top
Old 01-10-2019, 08:49 AM   #3 (permalink)
gtriever's Avatar
Photos: 3
Default
Same here. In fact, I couldn't get the engraver software to work on any version except v2.0.
__________________
Pull up a chair and visit a while :
https://www.facebook.com/thestatepen/
gtriever is offline   Reply With Quote Top
Advertisement
Old 01-10-2019, 09:04 AM   #4 (permalink)
TonyL's Avatar
Photos: 6
Default
Experienced the same when I bought a new computer with the same OS though (don't know why it wouldn't work). After much frustration and reading blogs, I loaded the older version software. I got it to work by installing the driver every time I launch the application. Now it works as long as I perform that extra step. Good luck.
__________________
Am I not destroying my enemies when I make friends of them? Abraham Lincoln
Peace,
Tony
Member of Local IAP Georgia Chapter meets quarterly in Roswell, GA
TonyL is offline   Reply With Quote Top
Old 01-10-2019, 09:44 AM   #5 (permalink)
chartle's Avatar
Photos: 0
Default
I use an different program called EzGraver. Not sure where its from but it has a lot more features than the software that came with the unit including dithering and sort a layered color separation thing. I don't think I ever found any real documentation but is there really any for the "OEM" software.
I've had mixed results using the dither and layer options.
https://github.com/camrein/EzGraver
https://github.com/camrein/EzGraver/releases
__________________
Cliff
chartle is online now   Reply With Quote Top
Old 01-10-2019, 09:47 AM   #6 (permalink)
gtriever's Avatar
Photos: 3
Default
Cliff, how did you get EzGraver to work with your machine? I've had no luck with it.
__________________
Old 01-10-2019, 10:32 AM   #7 (permalink)
rd_ab_penman's Avatar
Photos: 8
Default
Lots questions and answers found here.
https://www.facebook.com/groups/2730...oup_browse_new
Les
__________________
Innovation is the process that renews something that already exists and not, as is commonly assumed, the introduction of something new.
rd_ab_penman is offline   Reply With Quote Top
Old 01-10-2019, 10:32 AM   #8 (permalink)
Photos: 5
Default
Thank you all for the feedback. I'll try your suggestions and report back what works/doesn't work for me.
On a side note, I was looking at the screenshots I took of the images dropped into the 4.0 software and it almost appears to me like they tried to incorporate some sort of 'smart' cropping based on the image content. For instance, the concentric circles is cropped to a square aspect ratio where the original image equally fills that type of aspect. Whereas the owl is a vertically oriented rectangular crop and the Seahawks logo is a horizontally oriented crop; both of which, despite being in a square image file, the 'crop' seems to be roughly the shape of the actual image...just much smaller so it cuts off the image.
IDK though, for as cheap as this thing is, I didn't expect perfection and DID expect to have to tinker around with it to make it do what I wanted. Thanks again for all the feedback!
Old 01-10-2019, 06:21 PM   #9 (permalink)
chartle's Avatar
Photos: 0
Default
Quote:
I have the 1,000mw machine and just hooked it up, selected the port, COM3 for me, and pick either v1 or v2. they both seem to work.
This is a slightly older version I just found the newer version yesterday. Its a signature I'm working on for the bottom of my bowls. Plan is to glue a wooden coin in a recess.
__________________
Cliff
Old 01-10-2019, 06:31 PM   #10 (permalink)
chartle's Avatar
Photos: 0
Default
But From that Facebook group
Quote:
EzGraver 3.2 & 4.0 beta does not seem to work with the newer DK-BL (bluetooth) model. It will connect, but will not respond to any commands after uploading image to DK-BL. I've confirmed this on both Windows 7 x64 and Ubuntu 16.04 x64 using protocols 1, 2 & 3. The NEJE app works fine on the Windows machine.
__________________
Cliff
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
