How do you store your drill bits?
Mack C.
Passed Away Sep 29, 2018
Brooklin, ON Canada
I purchased some clear plastic pen tubes the other day and immediately upon opening the package got this brain wave.
It sure is better than those plastic bags some of the bits come in! Feel free to use this idea if you hadn't thought of it as yet. I'm sure there's many of you a way ahead of me.
How do I store my drill bits? Some are on the drill press table, some are on the bench, others are on my sander and some are actually in their rack. It doesn't matter how hard I try, they keep ending up there.
I took a piece of 2x4 and drilled holes in a row for the set I got from Daniel. I also have some room at the end for the extras that I know I will pick up along the way like extended bits and Pentel drill bit. Only thing I don't like is the wood sometimes swells and the bits stick but am thinking of adding some type of wax might help.
Made my own stand, just some laminex veneered particle board with appropriate sized holes drilled in it.
Not entirely happy but better than having multiple hidden storage areas.:eek:
Have begun cutting up electrical conduit lately. Will seal one end and make caps for the other,should help with keeping moisture at bay in my steel shed.
that's how i store mine. I bought some of the clear plastic cases for pens from rockler and labeled the caps and put the bits in and keep them in a special bin in my storage system.
I do the 2X4 thing also. I drilled each hole a bit over sized by drilling with the next larger bit. some still want to stick at certain times of the year. I actually have two of these now. one for my 115pc set of bits and one for my pen bits.
That's why God invented rare earth magnets. I have a small board with a row of magnets, labled with the bit size. It's on the wall one foot from the lathe.
Tom
My 115 bit set lives in the box that they came in:
My metric bits live in one like this one that I bought from McMaster Carr:
I also keep my bits in plastic tubes, used for holding pens. I label them on two sides and they lay flat in a tool drawer. It keeps them from getting dull or rusted. Easy to access and find the proper size when needed.
mine are temporarily arranged until i find something better. Right now, they are all in a drawer with a piece of light guage copper wire attached with sandpaper tags for according kits.
