monophoto
From time to time, we are all faced with the problem of drilling to a known depth. Yes you can buy drill bit stops that attach to a bit using a grub screw. Unfortunately, the set I bought from Harbor Freight are nearly useless - it comes with a small Allen wrench that is supposed to fit into the hex socket in the grub screws, but in fact it doesn't.
Alternatively, there is also the trick of adding a masking tape 'flag' on the bit to mark the desired depth.
But here's another idea - cut a slice from one of those plastic wine corks that are now used in a lot of less-expensive wines. Drill an on-axis hole (it doesn't have to be exactly on-axis - close is fine) in the slice that is slightly smaller than the bit it will be used with (eg, for a 1/4" bit, I drill a 7/32" hole). Slip this over the bit, and there you have it - a stop that will slide along the length of the bit, but that fits snugly enough that it won't move unless you really want it to.
