Diamond Credit Card tool
Warren White
Livermore, CA
I just purchased a Diamond Credit Card sharpener. I have looked at the vendors and on line and can't see too much in the way of instructions. I do note that they recommend some spray (which I didn't know I should buy with the tool) and am wondering if something like WD 40 might also work.
Also, if anyone knows of a link for some guidance on using the sharpener would be most grateful.
Thanks,
Warren
monophoto
Saratoga Springs, NY
I think the recommended lubrication when using diamond hones is water - - - possibly with just a tiny bit of dishwashing detergent to help break down surface tension.
Warren White
Livermore, CA
Thank you!
Since it doesn't seem to take much for each application, I will bite the bullet and get some lapping fluid.
Thank you all for the help.
Warren
