White Spots showing up days after finishing - Page 2 - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Finishing
  Forgot Password
Finishing It ain't a pen till it's FINISHED!
Welcome to penturners.org!
Reply
Old 06-08-2015, 02:08 AM   #11 (permalink)
edstreet's Avatar
Photos: 2
Default
MSDS = Material Safety Data Sheet.
Looks like this.
The section we are interested in is here in section 2.
60% 1,1,1,2-Tetrafouorethane
40% N-Hexane.
1,1,1,2-Tetrafouorethane...
Quote:
1,1,1,2-Tetrafluoroethane, R-134a, Forane 134a, Genetron 134a, Florasol 134a, Suva 134a or HFC-134a, also known as norflurane (INN), is a haloalkane refrigerant with thermodynamic properties similar to R-12 (dichlorodifluoromethane) but with insignificant ozone depletion potential.
Other uses include plastic foam blowing, as a cleaning solvent, a propellant for the delivery of pharmaceuticals (e.g. bronchodilators), wine cork removers, gas dusters and in air driers for removing the moisture from compressed air.
As for Hexane...
Quote:
Hexane is an organic compound made of carbon and hydrogen that is most commonly isolated as a byproduct of petroleum and crude oil refinement. At room temperature it is an odorless, colorless liquid, and it has many uses in industry. It is a very popular solvent,
__________________
Anyone can COPY, it takes a *TRUE ARTIST* to CREATE
-- In times of universal deceit, telling the truth becomes a revolutionary act.
Design your own Polymer Clay Pen Blanks by Toni, Detailed 'CA' Article
edstreet is offline   Reply With Quote Top
Old 06-08-2015, 11:04 AM   #12 (permalink)
Photos: 2
Default
Interesting... My first thought was that you were getting moisture under the finish during wet sanding. I had this issue on my first few pens, and it led to the same white spots in your photos. The fix was simply dipping each end of the blank onto a paper towel saturated with some thin CA to seal up the ends. Since I started doing this, my CA finishes came out perfect.
csr67 is offline   Reply With Quote Top
Old 06-08-2015, 11:56 AM   #13 (permalink)
Photos: 8
Default
Quote:
Originally Posted by edstreet View Post
NCF, sat city is non-acetone and in the 'good' class. All it takes is to pull the MSDS and find out.
Accelerator that causes white spots due to excessive use agents that attract moisture. GOOD accelerator does *NOT* exhibit this behavior. When using the GOOD accelerators you can drizzle the CA into a cup of the liquid and it will be clear.
Thank you again. I had not even thought to check out the MSDS.
Quote:
I wasn't doing the ends at first until I had seen a post on here and was told how to do it. Now I try to remember to do it each time!
Wolfeman46 is offline   Reply With Quote Top
Advertisement
Old 06-12-2015, 02:04 PM   #14 (permalink)
Photos: 0
Default Accelerator
I don't use a accelerator when I am doing a finish ........................
I rather let it dry on its own, I have had allot better first time attempts on putting on a CA finish if I don't use a accelerator.
farmer is offline   Reply With Quote Top
Old 06-12-2015, 04:56 PM   #15 (permalink)
Sylvanite's Avatar
Photos: 35
Default
That doesn't look like blush (spots from moisture) to me. I suspect it's sanding dust trapped in the open grain. When putting a CA finish on an open-grained wood, such as walnut, you need to fill the grain first. That can be done using sanding sealer, with a sawdust/CA slurry, or just by building up the finish high enough that the grain is full before you begin sanding.
I hope that helps,
Eric
Sylvanite is offline   Reply With Quote Top
Old 06-13-2015, 10:55 PM   #16 (permalink)
79spitfire's Avatar
Photos: 0
Default
Quote:
I hope that helps,
Eric
I think Eric might be onto it here, the dust sticking in the grooves may be from wiping it while the blank is turning.
79spitfire is offline   Reply With Quote Top
Old 06-14-2015, 12:26 AM   #17 (permalink)
TonyL's Avatar
Photos: 6
Default
I also practice this technique and once every 7 or 8 barrels, I will get some clouding and have to start over again. I am now blotting excess moisture from my MM, and also hitting it with another dab of thin CA before wet sanding. So I CA the ends while turning, then again, before wet sanding. I also make sure the barrel edges (90 degrees points) are CA'd.
I don't know if it will get me to 10 of 10 "perfect", but worth a try (for me)..
__________________
Am I not destroying my enemies when I make friends of them? Abraham Lincoln
Peace,
Tony
Member of Local IAP Georgia Chapter meets quarterly in Roswell, GA
TonyL is offline   Reply With Quote Top
Old 06-14-2015, 11:39 PM   #18 (permalink)
hilltopper46's Avatar
Photos: 62
Default
Respectfully, IMHO, you are over sanding - anything above 600 in preparation for CA finish is overkill and it may be contributing to your problem. Personally on walnut, you can stop at 400, again IMHO.
Also, it's OK to wipe with a paper towel while the blank is spinning, but then shut the lathe off and wipe in the direction of the grain with the lathe off. Wipe until you cannot see color on a white paper towel. This works really well with walnut or other dark woods.
The above works for me, but if I have a blank that is really expensive, really porous, and I really want to make sure it is ready for the CA, I wipe it down with acetone before the first coat of CA. I don't do that very often, I usually just do the dry wipe with a white paper towel in the direction of the grain.
__________________
Tony Rozendaal
East Troy, WI
Turnin' and learnin'!
Recently Created Pens
hilltopper46 is offline   Reply With Quote Top
Old 06-15-2015, 03:33 AM   #19 (permalink)
Photos: 31
Default
[quote=79spitfire;1774891]
After sanding I usually hit the blank with a bit of compressed air to get the dust out of the grain—then next coat of finish.
__________________
Jet 1221 VS
lwalper is offline   Reply With Quote Top
Related Content
Reply
Bookmarks
Tags
ca glue issue , finishing
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
