Please critique my process - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Finishing
  Forgot Password
Finishing It ain't a pen till it's FINISHED!
Welcome to penturners.org!
Reply
Old 02-16-2018, 02:51 PM   #1 (permalink)
Photos: 0
Default Please critique my process
1st post here. Below is a summary of what I have developed as a finishing process and am looking for some feedback as to how I can improve / change it.
Brand new to turning but this is what trial and error has taught me over the last week. Got my best results just last night. Two things have to be smooth. The wood and the CA. If the wood isnít baby butt smooth neither will the CA be. No amount of CA will make bumpy wood smooth. Like the old photographic analogy, you canít get a clear picture from a fuzzy negative.
Thanks in advance.
Sand from 80 to 600 using abranet. Donít skip grits.
Apply 3-4 coats of thin CA to fill any spaces (I might try Med CA for this part next time)
Sand back to 320 or wherever you need to to get rid of anything that is still shiny from the 1st coats of CA. Then you know itís smooth.
Sand back up to 600.
Wipe with slightly damp paper towel.
Apply 4-8 coats of thin CA. (some advocate for med CA for the final coats but I find it to be too hard to smooth out) Sand the CA to 600 again then use wet microfiber pads through 12K (Iíve found that the micro fiber pads wonít smooth the CA enough so thatís why I go over it with the 600)
Use EEE ultra shine abrasive wax (2xís if needed) (I tried using auto polishing compound but it didnít work as well as EEE)
Apply friction polish (DIY mix instead of $32.95 for Shellawax)
ramaroodle is offline   Reply With Quote Top
Old 02-16-2018, 03:03 PM   #2 (permalink)
greenmtnguy's Avatar
Photos: 94
Default
Try this for simple CA finish
https://youtu.be/eL9T-H8Hfv8
__________________
Alton
Chester, Vermont
ďOur Constitution was not written in the sands to be washed away by each wave of new judges blown in by each successive political wind.Ē
Hugo Black
greenmtnguy is offline   Reply With Quote Top
Old 02-16-2018, 03:20 PM   #3 (permalink)
Photos: 0
Default
I like that. Looks fast, easy and high quality. Saves a few steps. Gotta find the plastic polish. I've seen it mentioned elsewhere.
Advertisement
Old 02-16-2018, 03:34 PM   #4 (permalink)
Photos: 94
Default
It's not my video but I use a liquid car polish. I think any car polish will work as long as you have a smooth CA finish.
__________________
Alton
Chester, Vermont
Hugo Black
Old 02-16-2018, 03:44 PM   #5 (permalink)
Photos: 0
Default
I have some Maguires PlastX at home. Folks seem to like that stuff too. Thanks.
Old 02-19-2018, 11:26 AM   #6 (permalink)
pshrynk's Avatar
Photos: 0
Default
My brother says he uses headlight cleaner. Haven't tried it yet, myself, though.
pshrynk is offline   Reply With Quote Top
Old 02-19-2018, 11:38 AM   #7 (permalink)
Photos: 0
Default
Quote:
Yeah. Everybody says it's the same stuff. Just polishes plastic. Thanks.
Old 02-19-2018, 11:58 AM   #8 (permalink)
JimB's Avatar
Photos: 11
Default
Why are you applying a friction polish at the end?
__________________
Jim
West Henrietta, NY
JimB is offline   Reply With Quote Top
Old 02-19-2018, 12:05 PM   #9 (permalink)
Photos: 0
Default
Quote:
Cuz that seems to be the process that everyone suggests and is does take the finish to the next level over and above the plastic polish. The friction polish makes it smooth as glass.
Like I said, I'm new at this so my only knowledge base is what I have seen online.
Old 02-19-2018, 01:08 PM   #10 (permalink)
Member Liaison
leehljp's Avatar
Photos: 46
Default
Quote:
Originally Posted by ramaroodle View Post
Brand new to turning but this is what trial and error has taught me over the last week. Got my best results just last night. Two things have to be smooth. The wood and the CA. If the wood isn’t baby butt smooth neither will the CA be. No amount of CA will make bumpy wood smooth. Like the old photographic analogy, you can’t get a clear picture from a fuzzy negative.
Trial and error, the best teacher!
Pick up tips from others as you are asking. Some work and some don't.
The reason some work and some don't, And, some methods work for one and not the other is that:
1. there are differences in some CAs
2. Temp and Humidity differences in different regions affect finishes and times.
3. Relative instructions - what is "sand softly to a 250LB man" is "sand moderately hard" to a 125lb person; what is a "few seconds" to one person is 30 to 40 seconds to another; Speed of lathe when sanding is relative also - some sand at 1500 and above and some sand at much less than 1000 rpm and some at 200 - 300 RPM.
How one person interprets the actions of another in following directions is highly relative without each other realizing it.
You have discovered what works for you; keep trying it until it is repeatable. Next, with the changing of seasons and humidity swings, you may notice (with experience) a difference in the curing times.
Next, read other methods, and try them on a simple plain wood pen blank, not for the purpose of making a pen but learning new methods. If pen turning stays with you for more than a couple of years, your expanded experience will enhance your finishing techniques. Don't be afraid to try other methods. But for now, work on getting one down and repeatable.
Great looking finishes on those two pens!
__________________
Hank Lee
Experience is what you get when you don't get what you wanted!
leehljp is offline   Reply With Quote Top
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
