OB Shine Juice
Bobostro61
Chicago, IL
I'm sure many of you have seen Captain Eddy's OB Shine Juice. The recipe I believe calls for 1/3 denatured Alcohol, 1/3 boiled linseed oil, and 1/3 Shellac. If I was to use flake shellac instead of the liquid, how much of the flake would be needed for 2 oz. denatured, 2 oz. boiled linseed? If I remember, the flake can be dissolved in the denatured alcohol.
Thanks,
Thanks,
Jeff Jewitt one of the best
Mixing Shellac - Fine Woodworking Article
Jgrden
hOUSTON, Texas
Hmmmmm, I am looking for a finish to antler or wood that gives a nice shine. This is new. Would you apply it the same way as BLO and Cyanoacrylic? Getting tired of the BLO/
superglue application. Need a glossy shine with depth.
KenV
Juneau, Alaska.
Bob
Conventional shellac is a 2 pound cut. That means two pounds of shellac flakes mixed in a gallon of high purity alcohol. I usually dilute to a 1 pound cut by mixing equal parts of 2 pound cut with a high purity alcohol.
You can do the math for smaller quantities, but a pint of alcohol is about the smallest quantity practical.
High purity alcohol does not come from a big box store. Some sold there is up to 35 percent water. Head to a paint store, ask about water content and expect to pay more. The serious shellac mixers use everclear from the liquor store.
Water and shellac do not play well together.
