Finishing Bushings
jd99
Ontario, CA United States
I was going to make some finishing bushings this afternoon, and this is what I came up with. Figured I'd make them out of delrin and they should be a universal type to be able to work with all the kits (unless there are kits out there with tubes bigger then 1/2")
Figured one center (double angle) and two end (single angle) bushings would be all I would need.
Any one got any suggestions or comments please fell free to let me know.
  • Finishing bushing.pdf
Papo
Winter Haven, Fl.
Very cool Danny.
I believe is Johnnycnc that also makes and sells these out of delrin.
I happen to drill out 2 pieces of 2"x3/4 round delrin rod yeaterday thinking about the same idea.Thanks for the layout I needed that.
bitshird
Adamsville, TN, USA.
I turn the ends of mine down to .226 so they will just fit into a slimline tube, They don't last a long time since they wind up a bit under the mandrel size, but I like to be able to seal the ends of the wood as well.
jd99
I got the size for the small end from my smallest bushing (the 7mm slim lines).
Additional note I just turned thes and the only thing I might change is the length maybe make the 1/2" dia. part shorter I didn't know how long my mandrel was when I made this drawing; and you can't get two tubes and the three bushings on the mandrel.
not sure how I would turn them with out the 1/2" dia being real short though I used 1/2" dia, delrin and held it in the 1/2" 5C collet on my metal lathe to turn them.
Most of the time I finish one tube at a time anyhow so it will work.
Carl Fisher
Cape Coral, FL
I like the concept of the tapered bushings. So much easier than having individual sets for all the different kit styles.
Very cool/
hrtndlr
Colorado
I use short pieces of brass tubes for finish bushings on slimline pens. I am able to seal the ends of the blank and not accidentally glue the bushing to my workpiece.
ironman123
Central Texas
I made mine from 1/2 inch diameter acetal with 60 degree pointed end to go inside tubes. One had a 1/4 inch dia. shaft 3/4 in long to go inside my mandrel holder and the other has a center drill hole in it for the tailstock.
They work but I decided to make another set from 3/4in. dia. acetal.
Ray
Mack C.
Passed Away Sep 29, 2018
Brooklin, ON Canada
There's really no need for the 0.10 nub on the ends. Considering these go on an A mandrel, the bevel at the end will go inside whatever size tube you are using, or at least push up closely to a 7 mm tube.
jd99
I thought about taking them to a point, but then I thought the point would eventually break down because of lack of strength and I would have to make new ones more oftin, so i measured the smallest bushings and made the end a little smaller in dia then them.
That way there would be more bearing surface there then just the .010-.015" pushing against the brass tube, if I had cut then to a sharp point.
I figured out a way to mass produce these, (well not mass produce but make a lot fairly easy), and I might make some up and provide them to the IAP members if there is any interest, (at a little above cost) I think I'll just make the single angle though.
Danny
rherrell
Pilot Mountain, NC
You don't need to go to all that trouble. Just put a point on some Delrin and use it as centers...
attachment.php
I have a revolving drill chuck in the tailstock.
glycerine
Fayetteville, NC
That's a good idea, BUT, I find that it's much nicer and faster for two piece pens to be able to apply CA at the same time. And it doesn't take that much longer to drill a hole in the delrin so they fit on a mandrel...
