Is Finish needed over engraving & Colorfill
randyrls
Harrisburg, PA 17112
I am about to bestow two pens on the preachers at our church.
I had them engraved and then I color filled them.
Is an "over" finish needed?
Thanks for any information you can supply....
I didn't want to hijack the other thread about almost the same question.
ed4copies
Local Chapter Manager
Racine, WI, USA.
If its a wood pen, I agree with Constant.
If it is resin, it's debatable. I believe CA is likely to chip off some resins.
Dalecamino
Local Chapter Leader
Indianapolis, In.
I have been finishing my pens as normal , then I take them to the engraver . If they require any filling , I use Rub-n-Buff from the Arts & Crafts stores . They have an assortment of colors . You need to have a smooth surface , as this stuff will fill every scratch . DAMHIKT :redface: :rolleyes:
ed4copies
Racine, WI, USA.
GEEEZZEE, Dale
Hey Dale,
Why DIDN"T you POST that handy-dandy tip at the time!!!
HOW TO FIND YOUR SCRATCHES, section!!!
Sylvanite
I think it's a matter of personal preference. Color-fill typically leaves a below-flush surface. This accentuates the "engraved" look. If you like that, then fine. If you prefer a smooth surface, then a built-up finish (such as CA) yields a flush marking.
One advantage of the smooth surface is that it will not collect dirt over time.
Regards,
Eric
RussFairfield
Passed Away 2011
Post Falls, Idaho.
A finish may be needed to level out the wear patterns of the different materials. If keeping a uniform gloss is important, then the pen should be given an overcoat. Forget about it if the filler having a different gloss from the pen doesn't matter.
