workinforwood
Over the years material costs continue to rise but I have never passed those costs to my customers. Instead I constantly make improvements to how I produce things to save time and materials. With rotacrylics there is a few dozen at least processes and expenses going on...it's not just magical rods appear and just need loaded into a machine and then packaged. I have things set up like a production line which has several different staging areas from start to finished product.
One of the big costs and time consuming processes is the molds. A well made mold saves time and resin...but what most don't realise is you save here but lose there. Silicone actually costs more than resin, so it's kinda funny when you here resin saver mold but the resin saved was transferred into silicone. Mind you over time there is savings because you pour 60-80 blanks per single mold before that mold requires replacing. So if you are building custom molds you want to try to reduce the use of silicone but more than that it's the time it takes to harvest molds that matters most!
It's hard to believe but I have been pouring 18 rods at a time, 36 over two pots. My mold however is only 6 rods, and I only have 1 mold die, so I must create 6 molds and each mold takes 2 days to cure. It's an antiquated process. I sat down and re engineered the system so that a mold is now 9 rods instead of six and the finished mold will only be 1/4" larger base size. I am also building two identical dies, so I can create 18 rods worth of mold in 2 days and at the same time should save about 30% silicone used. The real saving though is 4 days to replace molds instead of 12 days.
I am sharing a few pictures but I can not show everything, especially how finished dies look. I spend countless hours innovating new techniques and over the years I have had countless ideas taken from me, so I now only show a little bit of stuff and force others to engineer their own equipment. Nothing sadder than seeing others profit off your personal creativity.
This photo is my old system...molds upside down
