Reverse turning?
SkookumPens
Puyallup, WA, USA.
You can use it for sanding. It will allow you to sand the fibers that have laid down. You can use it for hollowing. It makes it easier to see what you are doing. You need to be careful because your chuck may unscrew. Some chucks have a set screw that will prevent this from happening.
Craig Chatterton
Puyallup
Turned Around
Houston, TX
I don't have a reverse on mine, but if I had one, the only time I'd use it would be to reverse sand the wood to get the fibers going the opposite way. Right now, after every grit I use, I hand rotate the blank while I sanding with the other.
monophoto
Saratoga Springs, NY
1. Sanding
2. Bowl and hollow form turners sometimes turn in reverse, cutting on the side of the piece on the opposite side of the lathe from where the turner stands. It can be easier to see what you are doing inside a bowl or HF when you are turning in reverse. But this would not be an especially useful thing for pen (generically, spindle) turners
magpens
Canada
I'll be getting a new lathe in a few days. A Rikon 70-220VSR...you can reverse this lathe...can some one tell me when that would be used when turning. Thanks
When you are using a cloth to polish your pen blank, and the rag (and your arm) gets wound around the workpiece, then you can unwind by putting your lathe in reverse !!!!! :biggrin:
Band Saw Box
Passed Away Dec 8, 2021
Hampton, VA 23666
So Mal if it get wrapped up the other way you can go forward :biggrin::biggrin:But if you make a mistake will it put the wood back on when your in reverse? :):)
Charlie_W
Sterling, VA USA
Congratulations Dan on your lathe upgrade!
You will enjoy the extra size, weight and horse power as well as the reverse.
The slow 250 rpm will be helpful when you apply CA.
magpens
Canada
That's right, Dan, you can play the movie backwards and put the wood back on :biggrin::biggrin::biggrin: !!! ... Sometimes quite useful .... (I wish !!)
darrin1200
Lyn, Ontario, Canada
I have actually used revers when working on some small items. I cant get behind my lathe, and sometimes leaning over is not the answer. A draw bar is highly recommended when doing this and very light cuts.
I sometimes do the inside of my ring blanks this way.
Skie_M
Lawton, Ok
Most of the reasons for why a lathe would have a reverse function are already listed .... sanding, inside turning, finish application for better coverage in all the nooks and crannies, ect...
Another reason would be for threading operations, where you are cutting threads on your lathe with a REVERSE PITCH (left hand thread cutting).
TurtleTom
Checotah, Oklahoma 74426
It prevents the necessity of a slotted tool rest when turning on the far side without a reverse. It is used mostly for bowls with a pronounced curve to the side.
Getting a chisel in there normally requires you to lean way way over the ways, so to speak.
