Paraffin wax or something else? - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Build the Tips, Tricks, & FAQ Files
  Forgot Password
Build the Tips, Tricks, & FAQ Files Have a tip, trick, or a Q&A for the FAQ? Post it here.
Welcome to penturners.org!
Reply
Old 11-08-2011, 04:09 PM   #1 (permalink)
AeroCustoms.com's Avatar
Photos: 24
Default Paraffin wax or something else?
What is a good way to coat pen blanks to see what they will look like polished up besides misting it with water?
It would- could also be a good wood sealant if the entire blank was coated. I was debating on buying a paraffin wax heater & dipping them?
Suggestions?
__________________
New webpage http://ncwoodart.com
AeroCustoms.com is offline   Reply With Quote Top
Old 11-08-2011, 04:22 PM   #2 (permalink)
Woodlvr's Avatar
Photos: 21
Default
I was told that Acetone works or is that just for cleaning? Maybe a light swipe of tung oil so that it did not absorb very deeply?
__________________
Mike
Woodlvr is offline   Reply With Quote Top
Old 11-08-2011, 04:22 PM   #3 (permalink)
Photos: 0
Default
To see the grain I would wipe them w/ MS or DNA which will evap rather quickly. To seal you could use wax, I see some folk that buy sentless candles and melt them and coat the blanks. I would only coat the entire blank if checks are a real concern and this will only come from trial and error. Burls should be 100% coated but I would not coat a mesquite or anything like that all the way, just the end grain and a little side grain. I personally dip the ends of my blanks in Ancorseal and leave it on thick. Take almost a week to dry all the way but I have had success w/ that.
Justturnin is offline   Reply With Quote Top
Advertisement
Old 11-08-2011, 05:56 PM   #4 (permalink)
Bree's Avatar
Photos: 3
Default
I use DNA. Schlepp it on there and voila you have a good look at the figure... then it's gone.
If you are planning to apply a CA finish to the blank don't wax it or even get wax near the blank or you may well cause the CA not to stick properly.
__________________
Stay safe out there!
Bree
What a long strange trip it's been!
The 60's will never leave, if we refuse to leave them!!
Bree is offline   Reply With Quote Top
Old 11-08-2011, 10:58 PM   #5 (permalink)
Chapter Steering Committee
ssajn's Avatar
Photos: 0
Default
Isopropyl alcohol works well. Drys fast and won't raise the grain like water. And it's cheap.
__________________
Dave
Wisconsin Chapter Leader
http://woodjunky.weebly.com/
My money talks to me, it says good bye.
A penny saved is a government oversight.
ssajn is offline   Reply With Quote Top
Old 11-09-2011, 12:15 AM   #6 (permalink)
IPD_Mrs's Avatar
Photos: 0
Default
I clean my blanks with Acetone - then if I really don't see what I want to be able to see - I will gently sand one side (pick the best and the worst) re clean and ultimately even shoot a quick coat of spray lacquer on them. This is especially good if you are wanting to just photograph the blanks for some reason.
Linda
__________________
Browse our vendor Catalog for your IAP code- we'd love your feedback.
http://www.indy-pen-dance.com/sigpic3990_6.gif
IPD_Mrs is offline   Reply With Quote Top
Old 11-09-2011, 05:03 AM   #7 (permalink)
rherrell's Avatar
Photos: 82
Default
Mineral spirits
__________________
Rick Herrell
Pilot Mtn.,NC
"The pain of using a cheap tool lingers long after the joy of saving money has passed"
rherrell is offline   Reply With Quote Top
Old 11-09-2011, 06:58 AM   #8 (permalink)
Bree's Avatar
Photos: 3
Default
Quote:
Linda
Be aware that ordinary acetone can be a nasty chemical. It has a low flash point and is extremely flammable. Its vapor can flash back off lots of ignition sources. So no sparks, open flames, or heat sources when you use it.
Also be careful about combining it with anything else. For example, combining it with hydrogen peroxide can cause formation of acetone peroxide which is extremely unstable and explosive. Terrorists sometimes use it as an IED or suicide weapon.
Bottom line... be careful! DNA is a lot safer but even DNA should be handled with gloves as it is toxic. We sometimes forget that.
__________________
Bree
Old 11-16-2011, 04:55 PM   #9 (permalink)
Photos: 4
Default
Wood loses MC through evaporation if want to use wax as an end sealer okay. Leave sides uncovered, completely sealed blanks cannot absorb or release moisture. You want your blanks to reach EMC, before turning without air movement no MC evaporation. Better to lose a blank in storage than on the lathe or after assembly.
If going to ship pen blanks out of state okay to completely seal. Have to advise recipient skinner back so blank can reach EMC.
I use “Gulf Wax,” household paraffin wax, (canning, candle making, and many other uses) available at lot of grocery stores to end seal pen and spindle blanks.
Hot plate & old pot get it done, some say need a double boiler.
Wildman is offline   Reply With Quote Top
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
