Carl Fisher
I picked this up used and it seems to have a slight possible alignment issue or something?
When I run the auto feed, it cuts on a very slight taper so that the side closest to the head stock is more narrow than the tail stock end. Across a 5" run it's just less than 1mm smaller diameter cut.
Where do I start to troubleshoot?
Then my next question is how do I intentionally cut a short taper for something like a nose cone?
Thanks!
Thanks!
