Need an acrylic blank larger than the store sells it
endacoz
Brookfield, NY
I sold a pen in the following strawberry mesh pen blank. Acrylic Acetate #37 - Strawberry Mesh - WoodTurningz
The customer recently heard I started making finger rings with metal cores and they now want a ring out of this strawberry mesh. I need more like a 1 inch diameter of something like this bright and beautiful strawberry mesh that just shines so well. My own carry slimline pen is in this mesh. After 2 years it still almost glows.
Who can make me a blank line this?
PR_Princess
Sturtevant WI, USA.
Skie_M
Lawton, Ok
You MIGHT be able to use the ordinary size blank to get the material for that ring ....
What you will need to do is take a section about an inch and a quarter and cut 2 opposing corners off to give you your flats ... a diagonal section of the original square blank.
Take that section and sand the flats to give you a good surface for glue-up, and stick it to your faceplate (glue block) and turn it round ... once it's round you can work it from there.
