What do you use thin/med/thick CA for? What's best
redfishsc
North Charleston , SC
Just wondering today about the varying viscosities we have available.
What do you use each of the grades for? I know there's a lot of preferences out there.
Lets say, you are gluing on an accent/oops band--- would you use med, thin, or thick? Which is supposed to have a stronger grip? Does one get more brittle over time than others?
Monty
Group Buy Coordinator
Pearland, Texas, USA.
I use the thin for quick setting or stabilizing soft/punky wood. I use the thick for glueing in my tubes, filling small voids and finishing.
ctEaglesc
Passed Away Jul 4, 2008
Camden, S.C., USA.
Thick for oops bands,when finishing antler I use all of them.
Of course I also use thick for gluing in tubes most of the time.
JimGo
North Wales, PA
I use thin for stablizing, like Monty. I also use it as a sanding sealer, and for times when I want an "instant" bond. I use thick to glue the tubes most of the time, unless I've had run-out problems or if I've improperly "approximated" the size of the drill bit, in which case I'll use poly glue. I've switched to using odorless medium CA for a lot of the other stuff I do, like my CA finish or mixing with sanding dust to fill voids, and if the fit between the tube and the hole is sufficiently close, I'll use that for the tubes, too. That stuff is great, but expensive.
JimGo
North Wales, PA
You know, that's not a bad idea Eagle. I had been buying the 2 or 4 oz bottles, but at the rate I've started using it, the 16 oz might just be a good choice. Thanks for the suggestion!
ctEaglesc
Camden, S.C., USA.
I look at it this way.
At Monty's prices I can store it in the fridge.It winds up about 1/2 the cost of a 2 ounce bottle(actually less) than my "local" supplier 40 miles away.(80 miles round trip)Even if 8 ounces goes bad(and it never has) I am still not out anything.
Monty has a good product, great service with shipping and he is a great resource for the site.
When you do the math its a no brainer.
redfishsc
Eagle is DEAD RIGHT. I just ordered 2 of the 2oz bottles (a thin and thick), and some de-bonder for the same price I buy ONE 2-ounce bottle at my local supplier. Shipping included! Gotta love it!
