ahoiberg
has anyone else had the problem where your upper barrel, specifically on the slimline and euro pens, wants to "slip" past the point when/where the tip is fully extended?
then when you twist it back to closed, the grain is all out of alignment? i made my first euro last night and it was particularly evident with that style. i ended up sanding the inside of the brass tube which seemed to help a little.
has anyone else noticed this and if so, what have you done to combat it?
thanks.
thanks.
