Turning between centers bushing material
Cwalker935
Richmond, Va
What is a good material for making my own bushings? I have used corian but had one of my bushing split after several turnings plus the corian was not thick enough for larger bushings. Where can I find delrin (not sure if I spelled that right)?
Woodkiller
Smyrna, Tn. 37167
UHMW works good, aluminum works better. Those are the only 2 I have tried so far. Woodcraft has a 5lb bag of UHMW cutoffs that I use for jig parts and bushings. Lowes or Home Depot have aluminum barstock and round rods. The aluminum can be drilled and turned with regular HSS tools.
Dale Allen
Massillon, OH
Cody, I use 304 brass for the ones I'll use over and over.
It turns better for me than either copper or aluminum.
I've tried UHMV but for a bushing it seems too soft.
I use Delrin for the finish bushings. Delrin is a brand name and it is actually acetal.
You can get brass a acetal at McMaster, Zoro Tools and maybe Enco
frank123
Colorado
If you have a metal lathe use air hardening drill rod and harden the finished bushing.
It's unlikely you'll ever wear it out in normal use if you do.
Joey-Nieves
Vega Baja, Puerto Rico
I don't make many bushings, but when I do I... use Corian, what I found useful is that use a 7mm brass tube and glue 2 pieces of Corian together, then make the bushing to the proper size. since it's mounted on brass they won't split or come apart and you can use them on a mandrel, if needed.
