Squeaky front section
bgibb42
Hull, GA
I have a pen I finished last night that I have to deliver to a customer tomorrow. It is a Baron/Navigator. In testing all the functions of the pen last night, I found that when I screw the front section into the pen body with a refill in place, the threads make a horrible screeching sound. If you're not familiar with the Baron, this is a metal-to-metal connection. I have not had this problem in the past, but I need to figure it out ASAP. Any suggestions?
Mark
Pottstown PA
Maybe a dab of wax on the threads. Granted that is short term.
Silicone or a Teflon based spray might be a more semi-permanent fix.
Suggestions only. I've never tried it before.
DurocShark
Anaheim, CA
Wax will last a long time in that location. I do that to all the threads on my pens anyway. I just hate the metal on metal feeling. Wax works wonders.
jskeen
Crosby, Texas, USA.
Agreed on wax, just about any kind, from johnsons floor wax to an old candle stub. Just rub a tiny bit on the threads and work it in a few times, then wipe off any crumbs. Will last forever and be much less likely to seep out or cause the threads to back out than oil.
