Squaring Pen Blanks - Disc Sander
cnirenberg
Fort Myers, Fl
John,
Nice tutorial. The really cool thing about all of this is there a many ways of getting to the final result. This is a good example. Great job, and thanks for taking the time to put this together.
Wheaties
Omaha, NE
Good tutorial. I have been doing this for a while now and it works so much better for me than the pen mill. The only difference is I made my own squaring jig out of a scrap 2x2 piece of oak and an old mandrel (now that I TBC). I didn't realize PSI sold something like that
fernhills
Hellertown, PA, USA.
Yes, i chucked my pen mill in the trash after about a week of trying to use the thing. Been using the disc sander ever since. Never experienced unsquare blanks or all the big discussions about c/a chip out and all that, after making hundreds of pens. Carl
JakeAB
Berrien Springs, MI
I'm still kind of new at this, so pardon me if this is less than a brilliant question.
I've been using Rick Herrell's (rherrell) sanding jig to square blanks, with good results. It's simplicity itself, with no setup, engineering squares, or half a dozen ways the jig and sander supports can be out of square. How is the belt/disc sander jig better?
No criticism intended (great tutorial), just a question. If the belt/disc sander jig is a better way, I'll definitely want to invest the time to make one, or the money to buy the PSI.
Wheaties
Omaha, NE
What is Rick's way?
JakeAB
Berrien Springs, MI
What is Rick's way?
Sorry, I guess it would have been nice if I gave a bit more detail. You can see the mill here:
http://www.penturners.org/forum/showthread.php?t=42098
This mill is intended for final, fine milling. For the rough milling, I just use a Forster bit in my drill press to get close, before turning the blank. After turning, before sanding and finishing, I use Rick's sanding mill to finish the ends.
Like other jigs I've seen, it works best with 7mm tubes, but can be used with larger sizes with a little care.
Rangertrek
Bossier City, Louisiana, USA
I already had the disc sander, so no equipment to buy. It only takes a few minutes to set up and square the parts the first time; then, only a few seconds to check with a square prior to final sanding. I infrequently make any adjustments to the table or miter gauge, it stays set unless it get bumped or moved.
This is just another of the various methods available to penmakers for trimming blanks. I have also tried the method of using sanding discs on the lathe. That methods also yields great results. I just prefer this method as it is faster and easier for me.
I use it for all size pens that I make. I have trimmer sleeves of metal or delrin for each size blank. I also use it for a final touch-up trim to remove any CA that has crept over the edge during finishing.
Also, sometimes the lathe is in use while I am trimming blanks, so the sander is the available method.
JakeAB
Berrien Springs, MI
Thanks, John--for the tutorial and the explanation. I can definitely see the value of milling off the lathe. With the jig set up on the disc sander, I don't have to keep switching stuff around on the lathe to do the milling. I hadn't thought of that.
I also like the idea of different sleeves for different tube sizes. That will work just as well with the lathe-mounted sanding mill.
Thanks again (and sorry, I didn't mean to hijack the thread...).
daveeisler
Washington, DC, USA.
This method is fool proof, and you did 2 great things for us, first you show how to square up everything, and second, the most important is, you speak of the rod itself, I have been using this method with poor results, until I adjusted the rod, now it is fast and flat, and it far out last's those tiny sanding circle things, I paid 50 bucks for, and there is no chip out , as you can get from other methods, many thanks for a great tutorial. Dave
Gary Beasley
Marietta, Ga. USA
I just built one that uses the 1/4 inch pilot shafts from a pen mill. I can use any size 1/4 inch shaft I have now by undoing the setscrew and changing the pilot shaft for another. Pretty handy way of using both methods as needed.
Mikeshoops
Bakersfield, CA
Like Gary's jig, this is mine.
I built this using a V-Bit. I turn the blank on the nearest sized knock out bar. Used with an Inca HD 1000 and Bessey hold down clamp. I get perfect square fits and never take off too much wood, especially for click pens. The shop towel was added for background to the Macassar ebony blank.
Oh that is going to scare a lot of people:eek:
dryder
Raleigh
Does anybody else get a 404 error when requesting the PDF? I'm curious to see how Ranger does it.
Pete
I respectfully disagree.
How long have you been a member here??? Any time people mention tablesaw there is this fear for many here. The reason is you are dealing with such a small piece of wood near a spinning blade and the thoughts of getting fingers that close. Now many have gone on to making jigs to hold these pieces of woods and then of course there are those that are more woodworking savvy and know how to work around these machines. With the jig he shown there is no failsafe system to hold and control that piece around a high speed turning object which can do as much damage to you as a blade. These sanding discs have been around for years but are not widely used for various reasons.
For what we do, sanding on the lathe with a similar system and the use of the turning plate is alot safer. You can slow the lathe down which is a huge plus. You do not want to be sanding at those speeds. Even using a dedicated sanding station with disc is safer than that. Safety is what it is all about when working around machines and in a shop. This is just my opinion and I would not do it for what we do.
vtgaryw
Milton, VT
I started out squaring on my disc sander with the PSI Jig. I didn't like their jig for a few reasons. The biggest problem is that while it's very easy to square the mitre square to the disc, and the jig itself to the mitre square, the mandrel protruding from the jig is very difficult to get and keep square. It's a single point of attachment to the vertical piece of the jig. Also, once you get it square, you don't want to take it off to put in a different size mandrel.
After using the setup I posted earlier this year with the pipe centering jig, I'm happy to report it's worked perfectly for me. I've never had such consistently square blanks.
http://www.penturners.org/forum/f30/disk-sander-squaring-jig-125457/
-gary
