Slimline pens
OLDMAN5050
Passed Away May 15, 2019
Unionville, tn, USA.
Some china kits transmissions are prone to do this, just make sure that you are getting the transmission installed correctly and not so deep that the ink refill is allowed to extend all the way . The china kits have gotten better over the last couple years. The Taiwanese trans have not had this problem..
Maarten
South africa Roodepoort
The refill/cartridge on the slimline pen is a turn in and turn out system, but while you are writing, it is as if there is no lock system to keep it out, it turns back while you are writing.
its_virgil
Wichita Falls, TX, USA.
Not all do this. My experience is that many of the kits made in mainland China will so this but the kits (at least most of them)made in Taiwan do have a "locking" mechanism. The refill extends all of the way out then drops back just a little locking it in place.
Do a good turn daily!
Don
Hi can someone tell me why the slimline pens all turn back while writing,is there a special trick that you must do to stop the cartridge from turning back.
