Hello again everyone,
First, Ive a question for all you mandrel-less turners out there. I am considering going to the mandrel-less method for a couple different reasons like out-of-round barrels and bushing dust contamination from sanding. Do i need bushings machined specially to accept 60 degree centers or will the regular ones for mandrels work just as well? Also, when sanding, you remove the bushings completely and just put the centers into the brass tubes, right? If so, how do you keep from rounding the edges slightly? Its entirely possible that I am way off here, but i was unable to find specifics for these particular questions elsewhere.
Second, when using micro mesh, i seem to always get small rings near the ends of the barrels because of the edges of the pads. I always sand them out with the grain, but they are reintroduced with the next MM pad. Of course the logical response is not to let the edges come in contact with the wood, but this seems more easily said than done in my experience, so im just wondering if any of you seasoned turners and clever folk have any suggestions for me. ?
Third, ive read the other posts on enduro, but nobody can seem to agree on how long to cure or how many coats. Ive used it a few times following closely the directions that came with it, sanding through MM1200 and/or MM3600 then buffing tripoli and white diamond, followed with a coat of renwax (just like the feel of it), but have gotten unsatisfactory results. It just seems a bit dull to me.
Oh yeah, also please comment on the photo or whatever else you feel like saying.
