PVC
smoky10
Shepherdsville, Ky, USA.
Try the link below they have several colors including black.
http://store.nexternal.com/shared/StoreFront/default.asp?CS=plastiweb&BusType=BtoC&Count1=728328883&Count2=645469307
ahoiberg
Ames, IA, USA.
i've been trying to find a local source for this... doesn't appear all that many companies carry the type I colored PVC rod.
has anyone used straight acrylic rod with any decent results?
its_virgil
Wichita Falls, TX, USA.
I purchase PVC rods from Modern Plastics. They only sell in 5 ft lengths so I share with a friend. Here is a link: http://tinyurl.com/32cr42 If for some reason the link does not work, go to http://www.modernplastics.com and click "online purchase center" and follow the links to what ever plastic rods you need.
Do a good turn daily!
Don
Originally posted by ahoiberg
<br />where do y'all that use it get the black and other colored PVC?
its_virgil
Yes, I use the .75" diameter. If I had the time I would order a few rods of each color, cut them into blanks and offer them for sale here....hint, Hint, HInt, HINt, HINT. [:D] Here are pivtures of pens partly made from PVC rod. These are the only picures I could find.
Don
<br />don, do you get the .75" diameter rods?
