Pen disassembly tool
jckossoy
Columbia, MD, USA.
Does anyone know where I can buy or make a disassembly tool for a European pen (7mm hole). I had turned a beautiful piece of gaboon ebony and when I was putting it together, I pushed the mechanism in too far.:( Any help would be appreciated. Once I get it fixed, I post a picture of the pen.
Thanks.
bjackman
Salt Lake City, Utah, USA.
Even easier, & probablly cheaper.
You will need: 1/8" rod, 1/4 rod or bolt & a piece of reasonablly hard material.
Drill a 1/4" hole in the hardest material you have around. Corian works well, a fairly hard wood like maple will also work for a while.
You need a very long nail, or rod roughly 1/8" diameter to poke down through the transmission to the inside of the nib. Using a hammer on the rod sticking through the transmission and resting on the inside of the nib, tap the nib out.
Now, insert the transmission into the 1/4 hole and put the bolt into the other end of the pen/tube (where the nib used to be) and press, not hammer or tap the trans. out of the tube and into the 1/4 hole. You should be able to keep from doing major damage to the lower barrel wood as it is held by the blank while the trans. goes into the hole.
daledut
Swanton, Ohio, USA.
I got a complete set of transfer punches from Harbor Freight for $7.99. It has a size for everything. I have diassembled SL, Cigar, SL pro, and Euro with this set.
http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=3577
its_virgil
Wichita Falls, TX, USA.
I have a set or two of the HF transfer punches. Best $8 I've spent. Check out this for transmission removal.
http://www.stinggroup.addr.com/projects/turn/cushion/twist.html
Do a good turn daily!
Don
