Multi ply color blanks
qquake
Northern California
I got mine Saturday. They look nice, but feel light and soft, not like Dymondwood. I'll see how they are when I turn one.
You obviously never worked with it before from your comments. It will give the pen a lighter feel then. Nothing at all wrong with this material. I have worked both but hard to find these days. A deal that could not be passed up. Show us a comparison when you have a pen made up. :)
Thanks. I thought you guys had a secret source. I wanted in.:):):) The big difference with that material was the layers were coated in resin as opposed to this material being glued colored plywood.
KenV
Juneau, Alaska.
The Spectraply folks do sell a higher end resin loaded product called DymaLux.
Spectraply does go through the cactus juice just fine if desired.
eharri446
Marietta, GA
Just went and looked at the DymaLux that they sell. A 3/4" x 10" x 41" panel is $123.00. If you cut that into 3/4" x 3/4" x 5" blanks you would get around 100 blanks from that one panel. That being the case, the cost per blank would be $1.23 which is cheaper than it sells for at WoodCraft.
KenV
Juneau, Alaska.
Probably more managable is to get the 3/4 by 41 inch rods and cut to fit tube lengths as needed. Very little waste and a rod will make 8-12 pens depending on the style. One camo rod will make a bunch of bolt actions for $20 and shipping.
  • Like
Reactions: RKB
All one color. The spectraply is 1/3 that price. For pens it is not worth that to me. I use the dymondwood for my watch bands for desk watches. Alot has to do with what you are making with the material.
