How to stop glue bottle from clogging
Tropical
Ok, I am my wits end with the Hot Stuff glue I am using. For the first couple of days I had no problem digging out the residual glue from the bottle tip. But now.... I used to use a needle to open up the hole... kinda shove the needle down but the fear of stabbing myself with the needle compounded with the fact that I now need a vice to press the needle in the tip is making things considerably harder. Is there any way of preventing the hole from clogging up the spout? I think I read somewhere that you can put a pin or something in the hole of your glue bottle but I wasn't sure if this applied to regular carpenter's glue or to these fast drying, CA, glue as well. Your thoughts would be greatly appreciated. I am running out of bottle spout to cut off!:(
DCBluesman
Passed Away Mar 3, 2016
WOODBRIDGE, VIRGINIA
The problem stems from the tiny amount of glue that stays in the tip when you close it due to surface tension. I deal with it by turning the bottle upright, taking a piece of paper towel and squeezing the bottle until air pressure forces the to the top of the tip and it is wicked out by the paper towel. I've had no problems since I started doing this. [8D]
low_48
Peoria, IL, USA.
I never put the cap on. If you want to put the cap on, lightly rap the bottom of the bottle on the bench. Wait a couple of minutes and any remaining glue will settle back into the bottle. To check, lightly squeeze the bottle and you should hear air moving in and out. Then put the cap on.
its_virgil
Wichita Falls, TX, USA.
I must confess...I too am a capless CA user. I never return the cap to the tip, never have a clogged tip, never have a glued cap or pin and when I invert my CA bottle the CA always appears. Do I have to relinquish membership and attend a CA pplicator sensitivity class?
Do a good turn daily!
Don
Originally posted by Tropical
<br />Ok, I am my wits end with the Hot Stuff glue I am using. For the first couple of days I had no problem digging out the residual glue from the bottle tip. But now.... I used to use a needle to open up the hole... kinda shove the needle down but the fear of stabbing myself with the needle compounded with the fact that I now need a vice to press the needle in the tip is making things considerably harder. Is there any way of preventing the hole from clogging up the spout? I think I read somewhere that you can put a pin or something in the hole of your glue bottle but I wasn't sure if this applied to regular carpenter's glue or to these fast drying, CA, glue as well. Your thoughts would be greatly appreciated. I am running out of bottle spout to cut off![:(!]
B
Bill Baumbeck
Guest
Take the clogged tip and place it in a sealable glass jar containing acetone (an olive jar, for example). Let the clogged tip sit overnight and the acetone will dissolve the plugged end.
Having extra tips on hand will make life easier.
BB
Oak Ridge, NC.
Originally posted by DCBluesman
<br />I might try leaving the cap off, but the smell of CA makes me [xx(].
Lou,
I got a quart size pickle jar, looks like a pickle barrel. Don't remember the brand name but they were dill pickles and very good. But I digress.
I put two 2oz. bottles of CA glue, thin and thick inside the pickle jar with the lid on. Leave the caps off. The pickle jar contains the smell. I only open it when I need one of the bottles of CA and then I sit the lid back on the pickle jar so the smell stays inside.
Never had a clog yet.
wayneis
Okemos, Michigan, USA.
I use the little rat tail tips and do not plug the hole. The tail sometimes helps to deliever the glue where I want and in a smaller amount, like a tiny drop or two. After use I tap the bottle bottom on my bench and give it a little squeez and do not have any problems.
Wayne
dougle40
Essex, Ontario, Canada.
I use the tapping method too and fro the most part it does work but I also have the extra tips handy . I like the idea of soaking them in acetone though to clean them , I'm going to have to try that one , it'll save on buying all those extra tips .
Oak Ridge, NC.
One thing about acetone. Excellerator is acetone. I wouldn't take a freshly acetone cleaned tip and put it on a bottle or you may find the whole thing solidifying on you.
dougle40
Another good way is to store your bottle upside down . That way the air is in the bottom of the bottle and any hardening will take place there and not in the tip .
I've been storing my Polyurethane glue That way for well over a year now and it's still as good as when I first opened the bottle . It says on the bottle that the shelf life is 6 months after the bottle is opened and as you can see , I've extended that by over 100% .
I've attached a pic to illustrate my storage method .
I hope this is a help to someone .
<br />.
woodspinner
Dolores, CO, USA.
I cut the tip a little deeper to make a larger hole. Turn it right side up for a second or two and lightly squeeze to clear the tip. I can not smell my glue unless I am using it and I don't cap.
The only problem I have is glue build up on the outside of the tip. The build up can be scraped off.
Part of the problem may be your humidity. CA sets with moisture.
Good turning and be safe
Bill
