How much is 20 gauge?
Monterrey Mexico
Hello all. I am trying to get some metal sheets to use as decorations in my pens. I am confused about the "gauges" of sheet metal. Can someone explain how to measure or convert something like "20 gauge sheet metal" to milimeters? Or what those numbers represent?
Thanks in advance.
Mack C.
Passed Away Sep 29, 2018
Brooklin, ON Canada
cwolfs69
portsmouth, va
metal gauge thickness
depending on what material you are using 20 gauge metal will be about 1mm think. if you Google metal gauge thickness you can find many charts that will give you what you are looking for. these will vary by metal and by vendor. the best thing to do is find a metal gauge close to your needs and then measure or discuss with vendor what their particular products actually is. Here is just one of the many charts i found in about 30 seconds on google for sizes.
Gauge and Weight Chart
Monterrey Mexico
Aaahh Google!!!. I feel I need to apologize. I usually first ask and then Google, when I should Google in the first place.:redface:
Thank you all for your answers.
KBs Pensnmore
Murray Bridge 5253 Australia
Hopefully this is what you are looking for;
GAUGE (ga) - THICKNESS (inches)
8 - .1644
9 - .1494
10 - .1345
11 - .1196
12 - .1046
14 - .0747
16 - .0598
18 - .0478
20 - .0359 .0320 is Aluminum
22 - .0299
24 - .0239
Regards
Kryn
