Help w/ American Patriot
glenspens
Jonesborough,Tn. USA 37659
Has anyone had a problem with getting the refill to retract :mad:. working on one last night and can not get it to work :eek:......it may have just been to late needed to go to bed :hypnotized: or ??? Thanks for the help
WriteON
Florida & Pa
If it's not the nib......Sometimes the black plastic end is tight. I had to reduce the diameter slightly. Hand check with and without spring.
Sawdust1825
Illinois
I had the same experience. I stretched the spring and that helped. Another I tried the spring from a PSI bolt action which is the same cartridge but different heavier spring. It worked without issue which is why I stretched the spring to increase the compression tension.
