ok, not being sarcastic here (for a change) but I must be missing something. What does this widgit do for $60 that you couldn't do with a fairly simple homemade version simply cut from a block of nice stable hardwood with a handle on top and some nonslip stuff on the bottom. I know that the center section is adjustable, so you can theoretically use it for lots of different widths, but really, how many times do those of you that have one use a size other than either the minimum thickness, or 3/4 to 1 inch. The slider on the far side would be useful to keep the jig from tipping, and giving you a place to push the work against the fence, and still have something between you and the blade, but again, a couple of slots and wingnuts and it's easily reproduced.
Keep in mind folks, this it the guy who posted the pics of my left hand minus the tip of the index finger about a month ago, so I'm seriously in the market for something that works, but I'm not seeing $60 worth of flexibility in that moveable center section. So somebody let me in on what I'm missing here.
James
