Fine point nib for Baron?
bassman00
Danbury, CT, USA.
Is it possible to get a fine point nib for the Baron FP? I see CS sells nibs. Will those fit? Can I just use the tip and keep the nice black titanium barrel portion?
Thanks.
PenWorks
Scottsdale, AZ
Paul, the CS nibs will work, but you will have the black & 10K look, I am not sure, if you can remove just the nib and replace it, and keep the black ti look. Don't think so.
bassman00
Danbury, CT, USA.
Thanks for the quick answer Anthony. I guess I'll grab some Jr Gent FP kits and extra nibs. A friend has been dropping hints for a fine point FP since I showed him my Koa Baron. He's not set on a wood or plating so I'm sure the Jr Gent will work.
Thanks.
PenWorks
Scottsdale, AZ
Paul, I thought the nib on the Baron, wrote kinda on the fine side , instead of a medium. Has he tried it? Most of my medium nibs are a thicker print than that. Just a though, that you could pass it off as a fine point.
bassman00
Danbury, CT, USA.
He asked about a fine nib after he wrote with it. Then he spotted the "Medium Point" notation on the nib. I noticed it writes finer than the medium rollerball. I'm new to these finer pens. First time using a FP actually. I figure I'll use it exclusively for a while to get familiar with it.
Thanks.
