Ebonite Finish?
SteveG
Eugene, Oregon 97404
I have the same question as posed by Phil, and am in the midst of my first ebonite attempt. Any additional tips out there? Thanks
Steve
turbowagon
Tucson, AZ
Here's how I do it -- similar to acrylics and resins. Just be sure not to build up too much heat. So it really helps to get a good finish right from the tool, so you can avoid low-grit sanding and heat buildup.
1. Turn with skew.
2. Wet-sand with 400 & 600
3. Wet-sand with 2400 -> 12,000 micromesh
4. Buff on buffing wheel with 2 stages of plastic compound
IPD_Mr
Zionsville, In
1. Turn with skew.
Like Joe said, but I do not always wet sand. Another good thing to use after sanding and buffing is Semichrome. It is what we use on vintage Ebonite so it is safe and does a great job.
