Drift wood
avbill
San Bruno, CA, USA.
I was visiting my father-in-law by the Pacific ocean. And I picked up some nice drift wood. My question is: Should I harden the wood with Mini-wax harder, or send it out and have it stabilized ? The wood looks like splatted.
Bill :)
wdcav1952
Activities Manager Emeritus
Bill, that is hard to answer without seeing the wood. Is it stable enough to cut into a blank? If so, consider drilling it, running a bit of thin CA in the hole and letting it set. Re-drill the hole, tube it up, and turn it using thin CA to harden the surface as needed. This is far quicker and sort of stabilizes as you go.
Jarheaded
Fairfield county, CT, USA.
I have been having great results with the Minwax wood hardener. The softer the wood, the better it works. I found that drilling a hole before I stabilize, does help with the penetration.
winpooh498
Junction City, Oregon, USA.
I have found some beautiful drift wood on the coast I just used ca as I turned it and it worked fine just be prepared to sharpen your tools often as there will probably be a lot of sand in the wood. good luck and show us some pics when you get some done:D[8D]:)
Dalecamino
Local Chapter Leader
Indianapolis, In.
I coated the blank with thin CA all over , including the ends . Just kept the CA on throughout the entire process . Had no problems . One difference is , my driftwood is Blue Mangrove from Florida .
